Author Topic: 69 K0 Final shaft oil guide-needed or not?  (Read 1538 times)
Offline Fasted
  • 99% done now
« on: April 21, 2007, 08:39:37 pm »
Hi all,
My question is if I actually need the Final shaft oil Guide Part # 15621-300-000 and the bolt that holds it in.  It is #10 in the attached picture.  It appears if its only purpose in life is to channel oil out through the final drive shaft to oil the chain.  I plan on shutting off the supply anyway so will it hurt?  Does it have  any other function?
Thanks,
ED
1969 Sandcast rebuild!
Offline mcpuffett
Re: 69 K0 Final shaft oil guide-needed or not?
« Reply #1 on: April 22, 2007, 03:07:43 am »
Hi Ed, i had the same question when rebuilding my 750 engine and it appears that you don't need it or the bolt , cheers mick.
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
« Reply #2 on: April 22, 2007, 04:10:02 am »
Plug it up guys I have used a  broken off sparkplug for years (cant find long enough bolt) cause it has to go in far enough to hit the hole that is on the side of the shaft cant just plug the end good luck seven fifty four ever Craig in Maine
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
Offline Fasted
  • 99% done now
« Reply #3 on: April 22, 2007, 10:15:14 am »
Thanks guys.
I will proceed forward with out them.  Less things to possibly come undone inside.
ED
Offline Meantimemoto
« Reply #4 on: April 05, 2020, 01:38:19 pm »
Thanks guys.
ED
So Ed, did you just leave this out completely or did you do some sort of mod? Mine is bent up and I’m considering replacing but if I can just leave it out entirely without a mod, I may just do that.
Jon
« Reply #5 on: April 05, 2020, 07:11:58 pm »
The oiling pan catches splashed oil from the final drive sprocket and dribbles it into the center of the hollow final-drive shaft for the metering screw-seal to lube the chain. It doesn't hold anything on.
