Author Topic: Quick and cheap parts cleaning!  (Read 7864 times)
Offline CBGBs
    • Ride or Rot vintage motorcycle event in FTW
« on: April 22, 2007, 06:41:43 PM »
1.Use extra fine 000 steel wool on bare aluminum, like the carbs and motor head. It will shine any discolored piece in about a minute. Just remove oil first.
2. Use Brass wire bushing for pieces like the exhaust collars. Mine looked horrible, but in just a couple minutes most of the rust was gone and the chrome came right back. No chemical or cleaners needed. Showroom shine.
 A brass wheel can be used to clean corroded nuts and bolts in a flash.
Try both of these on brass parts as well.
3. Shine your frame with rubbing compound or polish.
Please post other methods if they are very quick and easy. I'd like to see someone take a barn fresh bike and place in a bike show within 24hrs.
'66 CB77 Superhawk  '73 CB350G Cafe  '75 CB400F '65 S90  '78 CB750 SS
Offline Gordon
  • 750K1, 550K2
Re: Quick and cheap parts cleaning!
« Reply #1 on: April 22, 2007, 06:51:37 PM »
A little WD-40 on a paper towel will wipe the chain lube and dirt right off your rims and leave them nice and shiny. :)
Offline toycollector10
« Reply #2 on: April 22, 2007, 08:30:41 PM »
See the earlier thread on Penetrol. I'm just taking a break from detailing my frame using the product. It's doing a great job.
You can probably get a free sample by going to their website and filling in the form. They sent me about a litre of the stuff in 8 or so little bottles.
1969  CB 750 K0
1973  CB175
1973  Z1 Kawasaki
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« Reply #3 on: April 22, 2007, 08:44:29 PM »
I seem to recall that steel wool on aluminum is not a good option over the long haul.  Something about microscopic bits of steel being imbedded in the aluminum and maybe some sort of galvonic interaction or something.  Or maybe this is just all the cold medication kicking in and resulting in halucinations.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline merc2dogs
« Reply #4 on: April 22, 2007, 08:54:42 PM »
 no, it's true.  Using steel wool on anything softer than steel will embed small particals of steel in it.
 Bronze wool or stainless steel wool is the way to go.
 steel wool is ok on something that will be encapsulated with paint or varnish
 Sailboaters will realy get picky about it!
ken.
Offline CBGBs
« Reply #5 on: April 23, 2007, 03:02:02 AM »
I know, I know. Naysayers have your say. I have been using steel wool for quite a while now and have not seen any problems. Others have as well. I guess I should be seeing little specks of rust on the aluminum or something. I've never seen such a thing. :)
Offline dagersh
    • Photos
« Reply #6 on: April 23, 2007, 12:14:28 PM »
I keep hearing this. Where can these items be obtained?
Thanks!
Try marine supply stores - boaters are defnitely picky about it.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline merc2dogs
« Reply #7 on: April 23, 2007, 03:35:41 PM »
My local Ace hardware has bronze wool, in a few grades.
 I've seen stainless wool at Home depot, but quit shopping there a few years ago, so they may not carry it anymore.
Ken.
Offline francisew
  • Francis
  • Francis Esmonde-White
    • Esmonde-White.com
« Reply #8 on: April 23, 2007, 04:19:13 PM »
I read in one of the carb cleaning posts about using tin foil. I tried aluminum foil- it works really well.
Francis
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #9 on: May 01, 2007, 09:38:12 AM »
It is my understanding that you will not see anything, that is the problem, it causes an electrolytic action which erodes the aluminium so over a long period your barrels etc are being eaten away.
Regarding the carbs aren't they some sort of zinc alloy and not aluminium.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline MgMt CB550K
« Reply #10 on: September 19, 2007, 01:06:42 PM »
A good Cleaning product for getting carbs clean and other gunked parts is concentrated simple green.  I used Carb cleaner and a tooth bush which worked alright but soaking the carbs in the simple green worked amazingly.  Plus it's nontoxic and doesn't smell so bad.
1977 CB550K - Almost finished, haha that's funny
1976 CB550 - Current Project
marz450
« Reply #11 on: September 20, 2007, 05:08:33 PM »
I have been dealing with the cleaning of alot of aluminum parts latley and many are very badly oxidized.
Steel wool I find to be contaminating in many ways (the adverse effects on aluminium and the "shedding" of it all over my bench and work space)
What I have been using for aluminium parts is;
sand paper (600 - 1200 grit depending on the condition of the part) the black waterproof kind and wetsand the piece with 600, then 800 and so on up to 1000 or 1200.
Scotch Brite - Home depot sells this as "Synthetic steel wool" in different grades to mimick 000, 001, 002 etc. I also use this with water and it lasts much longer than steel wool and does a great job.
rubbing compound
Mothers aluminum polish.
I get great results from this method and get parts to a almost chrome sheen without contaminating any other projects, tools, parts, etc. with steel wool hair.
Some parts will not require the sand paper / wet sand step but it sure cuts through bad oxidization well.
hope this helps
marz450
« Reply #12 on: September 20, 2007, 05:14:52 PM »
as far as aluminum foil to polish pitting out of chrome;
Some say crinkle it up and dip it in water and rub the part with it, this works ok.
others say crinkle it up and dip it in Coca Cola and rub the part with it, I preferred the water as there was no difference that I could see and the coke is sticky / messy.
then I read a guy saying to crinkle it up and use WD/40 as a lubricating agent and this worked well, all methods helped remove the slight pitting that occurs on chrome but there were parts that just were too far gone (as always) but this is a valid method.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #13 on: September 20, 2007, 05:20:27 PM »
I dip the steel or bronze wool right in the mothers aluminum polish and use it on aluminum. It is true that little rust bits will show up when pieces of the wool get stuck in the aluminum, but by that time it's dull and needs it again.  ;)
 Matt.
Gallery at:
