Author Topic: 77 CB750K, rebuild number 5 I think ** new pic June 27th  (Read 2582 times)
suzukisam
« on: April 22, 2007, 07:17:51 PM »
Last year I acquired my father's 77 cb750.  He bought it is 84 and I remember him bringing it home in buckets.  He modified and rebuild it several times until 4 years ago when he lost interest.  That's where I come in.  I convinced him to give it to me and i proceeded to make it my own.  Right now I am in the "put back together stage".  Here are a few pics of my progress:
motor back in the newly painted frame
with the 94 Sportster tank I picked up
stretched swingarm, about 2-2.5 inches I think
homemade Santee style box and stubby kicker
that's it for now.
Marc
« Last Edit: June 27, 2007, 05:27:56 PM by suzukisam »
Offline 750goes
  • it will live
Re: 77 CB750K, rebuild number 5 I think
« Reply #1 on: April 22, 2007, 07:25:48 PM »
hope you got a strong leg for that kicker.. :)
suzukisam
« Reply #2 on: April 22, 2007, 07:38:34 PM »
It still has electric start, this is a back up.  I used it a few times last summer, it's not the easist thing to use but it can be done.  I actually stand on the ground facing the rear of the bike and kick it over with my right leg.
Offline 750goes
  • it will live
« Reply #3 on: April 22, 2007, 08:25:07 PM »
don't slip......................... ;) it hurts lots
Offline mcpuffett
« Reply #4 on: April 23, 2007, 02:58:52 AM »
Nice job your doing there ;), watch out for your Dad when he see's what your doing he may get his interest back  ;)    cheers mick.
Offline rhinoracer
« Reply #5 on: April 23, 2007, 06:58:14 AM »
Might be my morbid imagination but I want to see how that tiny sportster tank looks in the finished bike. ;)
What's the santee box for? I've heard of them but never seen where they go.
Baja native.
suzukisam
« Reply #6 on: April 23, 2007, 10:47:58 AM »
It is only slightly smaller than the last tank I had on it (see pic in my avatar). The Santee box hold all the electrics, reg and rec, solenoid, starter switch and button.
mcpuffett, he thought I was only doing a rattle can job again so he is REALLY going to be upset when he sees the semi-professional paint job  ;D
suzukisam
« Reply #7 on: April 23, 2007, 10:49:57 AM »
OH yeah, the box mounts on top of the motor, kinda on top of the starter plate off to the right.
suzukisam
« Reply #8 on: April 23, 2007, 07:51:09 PM »
Update from tonight. front end on minus wheel and brakes, swingarm on, carbs on.
Anyone else running a Santee elec box (or similiar) having clearance issues with the carb drain sticking into the box? Picture should explain it better.
suzukisam
« Reply #9 on: April 30, 2007, 07:14:33 PM »
A little more progress.  Wheels are on, new throttle tube, cables, new clutch cable.
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #10 on: April 30, 2007, 08:23:42 PM »
Awhile back I bought a well-used '70s-era CB750 chopper just for the motor. It had a (real) Santee box on it and while the carbs came close, they didn't actually touch. Had about 1/4" of clearance between the top of the box and the bottom of the carbs IIRC.
–Captain Horatio Hornblower
www.thehairynickel.com
suzukisam
Re: 77 CB750K, rebuild number 5 I think ** new pic
« Reply #11 on: May 01, 2007, 06:24:45 AM »
I figured that my homemade box was slightly off in the height.  After a little work I made it fit.
Offline dusterdude
« Reply #12 on: May 01, 2007, 08:17:12 AM »
how much trouble was it to mount the sporty tank,im thinking of doing that myself?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #13 on: May 01, 2007, 08:31:36 AM »
Are those stock shocks u got on that scoot or lowered ones ?
suzukisam
« Reply #14 on: May 01, 2007, 09:23:27 AM »
I had one on last year and it was not to difficult.  Kind of basic but it works.  Some flat bar steel bolted to each front mount on the tank and then bolted to the frame.  I will try and snap a pic tonight and post for you.
As for the shocks, they are stock.  Swingarm was stretched.
Offline ProTeal55
  • Est1968.com
« Reply #15 on: May 01, 2007, 09:45:01 AM »
Ya - i ask becasue I have an extended swingarm similar to yours and would have to go back to stock shocks (have 11'' short shocks now) if I plan to put it on my bike.
Looking good  ;D
suzukisam
« Reply #16 on: May 01, 2007, 07:26:56 PM »
here is how the old sportster knockoff tank was mounted at the front.  the new sportster tank I got will mount pretty much the same way, it will need longer bars though.
and here is the rear mount.
I found this older pic from about 15 yrs ago.  Same bike, different style.
Offline dusterdude
« Reply #17 on: May 02, 2007, 08:30:36 AM »
cool,thanks.so i reckon it fits over the frame backbone ok then.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
suzukisam
« Reply #18 on: May 02, 2007, 10:06:04 AM »
sure does.
suzukisam
« Reply #19 on: May 22, 2007, 06:48:15 PM »
I will try and get some pics up tomorrow.  other that figuring out a new seat it is essentially done.  Back to the question about the sportster tank fiting over the backbone....well yes and no.  It fits over but the petcock hits the outside right downtube.  I ended up with the tank sitting a little higher than initially thought but I am still quite happy with it.
Since adding my homemade Santee electrical box I am limited to what I can run for an air intake.  I have a breadbox style but it hits on the bar that holds all 4 carbs together.  I could run pods i guess.  Any jetting suggestions for either of these scenarios?  I am running a 4-2 exhaust with "just for show" mufflers.
thanks
edit*** I could not wait until tomorrow, here a few new pics
« Last Edit: May 22, 2007, 07:02:43 PM by suzukisam »
suzukisam
Re: 77 CB750K, rebuild number 5 I think ** new pic May 22
« Reply #20 on: May 23, 2007, 11:07:16 AM »
I think I may make a longer narrower seat.  the one on it is a little wider than I like.  Still up and the air about running a front fender.
Offline dusterdude
« Reply #21 on: May 23, 2007, 12:02:11 PM »
sure does.
sam,thanks for the update on the tank,i fitted my sportster tank onto my spare frame and the bottom of the tank lays on top of the triangular bracket that connects to the frame backbone,do you have the same issue.thanks
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
suzukisam
« Reply #22 on: June 27, 2007, 05:27:18 PM »
Here it is in better light.  I got lazy and have not finished the seat yet. I've put a little over 1000kms on it since putting it on the road May 22nd.
