Author Topic: Pods Thread  (Read 193580 times)
Offline ekim98
Re: pods v standard air box.
« Reply #300 on: September 21, 2008, 08:07:33 AM »
I guess I'm just lucky. I put EMGO pods on my 78 750k with a cheap mac 4 into 1 and it ran just fine with some 120 main jets. Didn't quite match the 1/4 mile speed and times as tested new but that was more me than the bike. No problem with idle or throttle response. But then again I wasn't looking for more performance just a look so I came out good on both sides of the debate and I saved some weight too.
Patriot Guard Rider - KY. Ride with Respect
78 750k  cafe bike sort of
67 305  Superhawk (working project)
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #301 on: September 21, 2008, 08:19:38 AM »
...I leaned out the airscrews to help cure the miss, didnt seem to help much...
...Has anyone had to lean out slow jets from running pods?
The slow jets and air screw do not effect anything past 1/8 throttle.
On my '81 650 custom with '79 engine with EMGO pods and stock exhaust I have at this point:
110 main jets, 47 slow jets, slow screw @ 1 turn, PD50B slide, PD50A needle.  Starts right up with choke, warms up in 5 minutes.  Have yet to take it for a ride.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
KingCustomCycles.com
Emgo Pods oil or no?
« Reply #302 on: September 28, 2008, 09:32:19 AM »
I have used Emgo pods on a bunch of bikes and it occured to me today that they may need oil like the K$N pods.  Of course, these are economy pods and instructions would cost extra.  Will oil resistance to air flow affect my jetting?
Offline zx12r
Re: Emgo Pods oil or no?
« Reply #303 on: September 28, 2008, 10:34:06 AM »
my guess would be yes, they need to be oiled(i always have), and the slight amount of resistance from the oil should not cause a problem, i never noticed any difference from oiling. i had a zx7 with k&n pods on it and when i cleaned them the bike would have a slight flat spot until they got a little dirty and then the flat spot would go away, sometimes a little resistance is a good thing.
01 zx12r, 84 cr500, 74 cb550
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #304 on: September 28, 2008, 10:43:42 AM »
I spray mine.
« Reply #305 on: September 28, 2008, 11:02:32 AM »
Anyone get the feeling there may be a difference between Emgo & K&N quality wise?
 I would totally trust K&N, but reading about the endless problems with pods on this forum, I would be a bit leery of the lower priced ones.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #306 on: September 28, 2008, 12:33:19 PM »
No question K&N are better built. But I have had the Emgos running fine on mine for years. It works, not changing the program now ;D
fuzzybutt
« Reply #307 on: September 28, 2008, 01:08:47 PM »
i always used the k+n chemicals on my emgo pods when i still ran pods
Offline Johnny5
    • CB350F build thread
Pods on a 1977 CB750
« Reply #308 on: October 06, 2008, 09:07:15 AM »
I thought I would post my settings since there are a lot of questions about pods and jetting. After working through the jetting over the weekend here is what is working beautifully on my bike (1977 CB750K, emgo pods, 4-1 Mac exhaust):
Carb settings:
#130 Main jet
2nd richest needle setting (one notch below the middle)
Floats set at 14.5mm (factory spec)
Air Screw - 1.5 turns out, then about another 1/8" of a turn
I love how smooth these 4 cylinders are.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
Re: Pods on a 1977 CB750
« Reply #309 on: October 06, 2008, 09:56:07 AM »
Thanks for sharing
Offline Johnny5
« Reply #310 on: October 06, 2008, 09:58:56 AM »
I've rec'd lots of help from various forums, this one included. I just want to do my part whenever I can. Hopefully, someone somewhere will find this useful.
1971 CB350
1973 CB350F
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
What CRC2 has to say regarding pods.
« Reply #311 on: October 13, 2008, 11:45:47 AM »
"Re-cleanable pod filters can add performance and make carb removal much easier. Re-jetting is required for most applications. Twins and 550 and smaller Honda fours usually do not typically need jetting."
Thinking this may cause confusion for people not in the know. I read this prior to buying my pods and frequenting the forums, but I know better now... Strange that they would say the smaller fours don't usually require re-jetting especially for the already lean burning years.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline kghost
Re: What CRC2 has to say regarding pods.
« Reply #312 on: October 13, 2008, 05:31:18 PM »
I'll bet whoever believes that has a full set of encyclopedias  ;D
Maybe even a spare bridge in Brooklyn  ;)
Stranger in a strange land
Offline Triffecpa
« Reply #313 on: October 14, 2008, 09:43:11 AM »
the 550 and smaller fours and the twins were mostly gone by the time that the OEM's had to go to extremely lean jetting for emmissions (early 80's), so they might be partly right.
The initial change to CV carbs where when things got screwed up.  Took them a few years to sort that stuff out.  Had a '81 CB650SC that was a biatch to get running correctly.
TR
Offline tygrant
To make my pods fit
« Reply #314 on: October 31, 2008, 11:45:26 AM »
so i got my pods in an i was pumped an then realized they would never fit. i got cheap ones off ebay and they are prety big so my idea is this. cut along the read line with the dremel. ten cut the peice out thats in the cap and re glue the cap on further down to make them shorter. ... think it will work or will i have to get new pods?
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: To make my pods fit
« Reply #315 on: October 31, 2008, 11:49:31 AM »
What are you trying to fit them to? I've seen the same ones fit to a cb750, a 550, and a 350.
550 was kinda tight, the pods hit part of the frame, but they still got em to fit.
No.
Offline tygrant
« Reply #316 on: October 31, 2008, 11:56:48 AM »
75 550f -well the pods in the pic arent the ones that im using. on #1 an 2 the pod actualy reachs the back of the frame rail thats in the way. i could smash them in ther maybe... but it will look like crap wont it. il take some pics tonight to show you
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #317 on: October 31, 2008, 12:02:16 PM »
Go ahead and smash em in, nobody will notice it unless they look really hard. They are under the seat and tank.
No.
Offline tygrant
« Reply #318 on: October 31, 2008, 12:12:00 PM »
BOOOO i bought them cuz they look cool haha
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline texaninseattle
  • lots of protein in my
  • OHH Canada
« Reply #319 on: October 31, 2008, 12:16:32 PM »
isnt there a thread here that says the 35mm ones will fit the 550 w/o smashing?
*edit*
here it is
http://forums.sohc4.net/index.php?topic=24352.0
just read the post by dustyc
« Last Edit: October 31, 2008, 12:22:36 PM by texaninseattle »
1978 Cb550k(Sold)
emgo pods
mac 4-1
105 mains
stock pilots
needles set 1 step richer than stock
IMS 2 turns out
1982 Suzuki GS850g
Offline Hope
  • How did I become an
  • SOHC member since '01
« Reply #320 on: October 31, 2008, 12:21:14 PM »
There is a thread around here that I started addressing this issue
http://forums.sohc4.net/index.php?topic=29437.0
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #321 on: October 31, 2008, 12:23:06 PM »
Damnit Hope, you beat me to it... :D
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
Offline tygrant
« Reply #322 on: October 31, 2008, 12:43:26 PM »
i actualy saw those threads before. I searched a whole lot after i had allready bought the wrong ones on ebay. i know i can get the smaller ones but i allready own these ones... that why im thinkin about cutting them. i think i can get it done and make it look nice, im pretty crafty with a dremel...
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline tygrant
« Reply #323 on: October 31, 2008, 01:07:50 PM »
do you think if i trimmed the out side two(1&4) and left the two inside(2&3) it would have enough of an effect on airflow to mess it up?
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline cafe750
« Reply #324 on: October 31, 2008, 01:25:45 PM »
My little brother actually did the cut, and glue the caps back on mod, after finding the pods too long. It does work. I would recommend performing the mod on all four, so that the airflow is the same across all four carbs.
Roy, Washington
