Author Topic: Pods Thread  (Read 137840 times)
Offline tygrant
Re: To make my pods fit
« Reply #325 on: October 31, 2008, 01:36:37 PM »
yea il just do all 4, thanks cafe750.
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline mystic_1
  • 1970 CB750K
« Reply #326 on: October 31, 2008, 02:33:24 PM »
Use a good adhesive.  That part is exposed to fuel vapor and heat.
mystic_1
- John Augustus Shedd
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #327 on: October 31, 2008, 02:44:54 PM »
The 39mm pods fit on the 77 and 78 550 only. If you have 76 and earlier, go with the unipods.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline tygrant
« Reply #328 on: October 31, 2008, 05:30:06 PM »
mystic_1
any good recomondations???  i was thinkin some type of two part epoxy?
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
« Reply #329 on: October 31, 2008, 05:53:58 PM »
or you could do what i did  ;D ;D
Offline mystic_1
  • 1970 CB750K
« Reply #330 on: November 01, 2008, 03:27:06 AM »
mystic_1
I'm not sure, two part epoxy might be too rigid and therefore brittle.  Silicone caulk would be too soft, so somewhere between those extremes I'd think.
There's an adhesive/sealant called Goop that I've used for some things, was pretty happy with it and it should do the job fine.  Any chemically resistant adhesive that dries semi-flexible should be ok.
cheers
mystic_1
Offline tygrant
« Reply #331 on: November 01, 2008, 09:22:16 AM »
i almost notched the frame like that. it was that or cut the filter i decided on cutting the filter because my filters are longer then that and i would have to cut the entier peice out and move it back. little too much fab work on a POS  for me. yours looks nice though
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline tygrant
« Reply #332 on: November 02, 2008, 02:24:05 PM »
so i cut them and they came out awesome. they look better than before!
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline Maxacceleration
Pods vs Airbox (550)
« Reply #333 on: November 13, 2008, 07:04:08 AM »
Does anyone know the performance gains (if any) with pods on a stock 550 motor?
Do individual pods take away from the smoothness of the 550 motor?
How about with adding just a cam to the stock motor (with header)?
Will the stock airbox allow for increased (bigger) jetting?
Thanks!
Olden is Golden
CR550F RD400 KZ550 KH500
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: Pods vs Airbox (550)
« Reply #334 on: November 13, 2008, 07:47:12 AM »
Search "PODS" and/or "AIRBOX"
This debate has played out several times already.
Offline edbikerii
    • Gallery
« Reply #335 on: November 13, 2008, 08:29:52 AM »
Yeah, if you've got a 77 or 78, you might want to have a look at the threads in my signature.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline gsgleason
  • new to this
  • 1975 CB750F
« Reply #336 on: November 13, 2008, 08:48:18 AM »
Pods will restrict air flow much less than the stock airbox, leaning out the mixture considerably.  you will need to adjust your carbs (jetting, needle position) to add more fuel.  If you're not willing to do that, keep the box.
Offline Johnny5
    • CB350F build thread
« Reply #337 on: November 13, 2008, 09:12:03 AM »
Dont pods do the opposite of restrict? They let in more air than an airbox that's why more fuel is needed in the jetting process.
« Last Edit: November 13, 2008, 09:14:34 AM by Johnny5 »
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline dusterdude
« Reply #338 on: November 13, 2008, 09:18:52 AM »
yes
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline goon 1492
  • Sucka Repellant
« Reply #339 on: November 13, 2008, 09:27:25 AM »
Your on the right track, follow ed's links. ;)
Man steppin' into here and hearin' about peformance mods in the vernaculation of a cam and header sounds like car jazz to me, Just missin' somethin about a huge carb and flowmasters with slicks. ;D
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #340 on: November 13, 2008, 09:50:08 AM »
somebody hide this thread from TT.    ;D ;)
seriously, use the search function. i'm pretty well there has been a thread with this exact same title. there are definitely many on the subject.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
« Reply #341 on: November 13, 2008, 10:11:46 AM »
Seriously paulages, I did. I didn't find what I was looking for.
I'll check Ed's links.
Thanks.
OK, one more question, is there a less restrictive stock filter replacement?
Olden is Golden
Offline Porscheguy912
  • I'm a Big Shot Ninja.
  • It's MR. Moustache To you SIR!
« Reply #342 on: November 13, 2008, 10:17:30 AM »
Thanks.
Hey max,
Welcome to the fourm.
Make sure you're using the search bar at the top right of the page and not the "google bar" on the left.
There is scads of pages on the subject. search "pods".
or look at my posts from about a year ago june and july. Thats when i was going through the same bit.
Cheers
Current: 1978 CB750F3
Past: 1974 CB550K
KingCustomCycles.com
« Reply #343 on: November 13, 2008, 10:20:15 AM »
Whats a pod?  ::)
« Reply #344 on: November 13, 2008, 10:23:10 AM »
Thanks Porscheguy!
I hope to have a whizzzbanger lol of a bike by winters end.
I am just researching what state of tune I want to go with.
Olden is Golden
Offline paulages
  • 1976 cb735
« Reply #345 on: November 13, 2008, 10:27:10 AM »
Thanks.
yes- uni makes a replacement.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline moham
  • .fnord.
« Reply #346 on: November 13, 2008, 10:28:34 AM »
Whats a pod?  ::)
It's what the mothership sends when it's time to go...
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
« Reply #347 on: November 13, 2008, 10:33:23 AM »
Allow me to refine your perception.
First, not all pod brands are the same or offer equivalent restriction qualities among the general class of "pods".
Some pods allow more air to pass at high RPMs (like red line and above), when inlet air speeds are high.  More air, more O2, can get you more power.
At lower inlet air speeds they simply reduce the vacuum levels in the carbs throats, which, in turn, have less suction draw on internal fuel jets.
Therefore to compensate, the orifices must be enlarged to draw the SAME amount of fuel the old jets delivered with a higher carb throat vacuum.
At low inlet velocities, the engine displacement and cam efficiency determine the air volume consumed. Inlet restriction here plays a non-significant role in 02 delivery, but a significant role in carb throat vacuum.
The only RPM range that PODS can improve power is at or near red line where the main jet dominates the fuel mixture.  If you plan to flog your motor at these high RPMS regularly, then pods may provide some benefit.
Anyone have a CB550 motor with pods and still getting 40-50MPG?  I suspect, many bikes with pods are over jetted, with the misconception that big jets automatically equal more power.  In reality, it often just makes the motor far less efficient.
Yes, the UNI NU-4055 is a drop in foam replacement.  I do not know how much it improves the airflow at and above Red line RPMs.  It does slightly lean the carb mixtures in the lower RPMs.  But, not so much that rejetting has been required.  I'm not sure about 550's with PD carbs, though.  With these bikes, the exhaust type becomes and important factor.
Offline paulages
  • 1976 cb735
« Reply #348 on: November 13, 2008, 10:34:55 AM »
just searched "pods airbox" and came up with 11 pages, but here a few good ones:
http://forums.sohc4.net/index.php?topic=22036.0
http://forums.sohc4.net/index.php?topic=34549.0
and this one for a good TT reply:http://forums.sohc4.net/index.php?topic=2123.0
there should be a "thoughts of TwoTired" thread (like the hondaman one) all about modifying carb setup and wiring. come to think of it, much of that is probably in the FAQs.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #349 on: November 13, 2008, 10:35:38 AM »
Whats a pod?  ::)
Is it time to go?   ;D
