Author Topic: Pods Thread  (Read 134889 times)
0 Members and 10 Guests are viewing this topic.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: Pods Thread
« Reply #500 on: October 26, 2010, 09:53:05 pm »
I got them from a local motorcycle shop (Lee's Cycles).  From what I can gather the main jet type is pretty popular it's the 77-78 slow jets that are hard to find.
I've read all 20 pages of this thread and countless others.  It's taken me about 2.5-3 months to get to this point. I was starting to believe that it couldn't be done.  It would have been a lot easier to just stick with the box.  But the drag pipes would have caused me to re-jet anyway. However, I doubt it would have been as hard to jet for exhaust alone vs the pods and exhaust.
At some point you must have read I used 138's  ;)
Offline Coyote13
Re: Pods Thread
« Reply #501 on: October 27, 2010, 07:43:47 am »
Zing
'78 CB750K.  Throttle ripper.
'71 CB100.  Grocery getter.
'01 XL883.  Panty dropper. Gone but not forgotten.
Offline RYNO
Re: Pods Thread
« Reply #502 on: October 27, 2010, 09:35:18 am »
RYNO, was the stock slow jet in '77 a 35 like in '78? And how diffifult was the swap considering that they're pressed in?
Yes they were.  Or at least that is what mine came with. Well, removing them isn't the easiest thing in the world to do but it isn't the hardest either.  Just remember that they are brass! They won't crush but they will snap.  So squeeze really hard and twist without tilting from side to side and they will come out.
At some point you must have read I used 138's ???
Yes I have  ;D I messaged you asking about the jets and your tracy tank! As I said before Thanks!
see thread http://forums.sohc4.net/index.php?topic=78009.0
Offline Kemp
Re: Pods Thread
« Reply #503 on: November 02, 2010, 01:14:16 pm »
Main jet - 110
pilot - #38 (stock)
Needle - 3rd clip (one notch richer than stock)
air screw - 1.5 turns out.
Kemp I am not sure about your needle position.  My CB550F needles are set at 4th notch (#1 being at the top of the needle) and I have a stock airbox with a stock 4 into 1 header and MAC muffler.
It seems like you might have gone leaner on the needle.  However you have larger mains than stock, maybe that puts your needle in the correct spot.  Please keep us posted, I'd like to know in case I switch to pods someday.
I had gone richer (raised the needle) but it was still soft/fluffy especially when I would rev the engine for downshifting. I went back to the stock setting (slot #2 from the top of the needle), main jet #100 and the bike runs much better. I think I could go up a bit on the main, maybe to a 102 or 105 although the plugs look okay, certainly not lean. I think it had a bit more jump with the bigger 110 main but I sort of made 2 changes at once (leaned out needle and dropped main) so I've confused myself. Will try just a bit larger main to see if it helps.
Offline gnarlycharlie4u
  • Far from being an
Re: Pods Thread
« Reply #504 on: November 03, 2010, 01:55:46 pm »
I know that there are different brands of the air cleaner pods I am looking for. I am looking to replace the stock air cleaner set up on my cb500 and cb550. What is the cheapest source for these pods? I hear that they can be had for somewhere around $10 each.
be forewarned... you generally get what you pay for.
that being said, I've gotten great deals from other members here. (Thanks guys)
of course... Ebay as well.
I have K&N filters and uni foam pods both work wonderfully.
the uni's go on my CR's which are stock jetting from factory and seem to be working alright. I also ordered a jet kit which I have yet to use. I will hang on to the jets for when I port the heads.
« Last Edit: November 03, 2010, 01:59:05 pm by gnarlycharlie4u »
Re: Pods Thread
« Reply #505 on: November 10, 2010, 09:53:05 am »
Does anyone know of a Pod filter that has an internal design like the one below, AND fits on Cb550 or Cb750 carbs?
Offline Soos
Re: Pods Thread
« Reply #506 on: December 18, 2010, 03:36:18 am »
Two tired, have you thought of trying to make a "nose cone" like the one you want to find, and epoxy them into an existing set of pod filters?
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Re: Pods Thread
« Reply #507 on: December 18, 2010, 09:59:36 am »
Yes, but that is only half the problem.  Do you know of any pods that radius the primary funnel near the carb mouth?  In some ways, I think that is more important.
Offline Freaky1
Re: Pods Thread
« Reply #508 on: December 18, 2010, 10:17:18 am »
I would think, much like the "nose cone" section you could make a adapter for the primary funnel. I've got a set of UNI-pods that have volunteered to be test animals. I plan to replace them with some nice oval K&N's shortly and not sure if I want to go postal on an expensive set but if I can make it work with the UNI's then maybe I'll feel more confident.
I agree with you TT, I think the carb mouth is the more important factor in this equation.
That which does not kill you leaves cool scabs which turn into awesome scars.
'77 CB750F Come on...were almost there!
Re: Pods Thread
« Reply #509 on: December 18, 2010, 10:23:47 am »
Don't forget about the "step" at the carb entrance, either.  Don't most pods go around the outside diameter of the carb mouth and avoid or ignore matching the inside diameters of the pod outlet to the carb inlet?  That is yet another turbulence producing artifact.
Offline Freaky1
Re: Pods Thread
« Reply #510 on: December 18, 2010, 10:34:29 am »
+1
I had an idea of trying to use the stock venturi from the original air box in a custom K&N setup. Someone had posted about an one piece oval K&N filter that turned on side would clear all four carbs, but couldn't remember the part number.
Offline sscardefield
    • CB Town - Just Rippin'
Re: Pods Thread
« Reply #511 on: February 02, 2011, 07:09:55 pm »
Running MAC 4-1 open and 35mm EMGO pods (the ones that clear the frame) on a '76 550k.
Sorry for bringing this thread back, but I am just about done with my first complete rebuild and am ready to dig into the carbs. I have just spent the last 3 hours reading various threads/articles  (including this entire thread) on carbs and how they work and what other people are running and blah blah blah. I think I have a pretty good grasp on it now, but am just confused on the main jet sizing. In this thread it is mentioned that certain jets are measured by hole diameter and others by flow. This is where I am confused.
The Keihin main jets come in increments of 5 (100, 105, 110, etc). So if you were to go by the formula posted earlier in this thread (http://www.motorcyclecarbs.com/Jetting_Rules_of_Thumb_W43C551.cfm), would a +5 size be a 105 or 125? In other words is a "size" an increment of 1 or 5 (+1 size is 100 to 101 or 100 to 105)? I'm just finding it hard to understand on how one guy can say he's running EMGO pods with open MAC 4-1 with 105's and it's running perfect and another guy can say he's running 125's with the same setup and it's running perfect. Obviously there is going to be some variation between bikes, and of course other variables to take into consideration (elevation, temp, etc), but doesn't that seem like an extreme difference?
Thanks in advance.
Offline scunny
  • don't call me expert
Re: Pods Thread
« Reply #512 on: February 02, 2011, 07:35:48 pm »
 on Keihin main jets the numbering equals size, eg 110 = 1.1mm
can't help you on the formula. I'm running a 650 with unrestricted 4 into 1 and unifilters. 120 mains and runs sweet. trying 130 this weekend to see what change if any happens.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Re: Pods Thread
« Reply #513 on: February 02, 2011, 10:54:27 pm »
Yes, it does.  The problem is that "guy's" reports are subjective and not calibrated to any sort of standard that can be reproduced.  "Perfect" can mean they were able to drive around the block and then type on the computer to post a brag.
Or, it can mean they drove across country with no other problems than stopping at every gas station for a fill up.
Still others, use very large mains and then over lean the slide needles to make the midrange tolerable (meaning, not perfect or actually correct at all throttle position between 1/4 and 3/4).
It is very rare that any actual, measureable performance testing is actually done, whether it be timed track events or a graph produced by a dyno.
No one has a calibrated butt dyno.  And many times, the ears hear louder sounds and the brain thinks, "wow, its faster since it makes more noise".
I believe the "formulas" bandied about are largely fiction, whose main goal is to give a false sense of well being in the experimenter.
Ever see the "formulas" tested or reinforced by dyno results?  Me either.
IMO
Offline edbikerii
    • Gallery
Re: Pods Thread
« Reply #514 on: February 04, 2011, 08:51:50 am »
The "formulas" are not entirely accurate, but my be a guideline with a safety margin on the rich side.
Remember that the 77-78 are different carbs altogether from the earlier models, so the jetting will most certainly be different.  The air passages are different.
I don't think I'm one of the "ride around the block and brag" types, as I went through quite a bit of trouble to ensure my carbs were jetted properly.  In particular, I tuned for the lowest running temps using my infra-red thermometer.  However, I DID NOT put my bike on an exhaust gas analyzer, nor did I dyno tune it.  I have put several thousand trouble free miles on my bike since I rejetted it, though.
Please read the posts in my sig if you want to see just what was involved in my carb tuning work.  I'm not knocking anyone else's experiences or preferences with their bikes, but I'd advise you to read the posts so you are more familiar with what is involved.
Good luck.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline vern401
Re: Pods Thread
« Reply #515 on: February 23, 2011, 11:10:59 pm »
I may be lucky but on 2 of my bikes that have pods on them I have not had to rejet them.
I got my pods from Ebay for about $40 per set of 4 pods. my main problem is rust in the tanks and wore out float valves not the pods.
1972 SL350
1978 750F SS
1979 XC500 Custom
1991 ZX600C4 Ninja
1982 KZ550C-3
Offline xedge4lifex
  • Trillz McGillz
Re: Pods Thread
« Reply #516 on: February 13, 2012, 09:48:38 pm »
76 550
Emgo Pods
stock carbs second to bottom clip
screw half turn out
ported head
low restriction exhaust
        Ran pretty solid, hot, cranked out 105 on the speedo, air bog at  anything under 3k @ 50% or more throttle
*2-13-12 Update*
Emgo Pods
110 jets
Bottom clip position
screw one and a half turn out
ported head
      Runs like a hall and oates song, very smooth, pulls from any rpm like a rocket, top end power is insane, ill play with the air fuel screw and see if i cant get it a little leaner on idle, other than that, very recommended upgrade.
Wake up, look up, there's a warmth up there
a reminder of peace, a reason to care.
Offline Ryan66
Re: Pods Thread
« Reply #517 on: February 14, 2012, 04:21:49 am »
interesting reading for usre
1976 CB550k (cafe project)
Offline heffay
Re: Pods Thread
« Reply #518 on: February 26, 2012, 04:54:35 pm »
73 cb350f
4-2 pipes
Swapped to pods while living a mile high in CO.  It ran less than ok, but I accepted it.  After moving to AZ and 1000ft, ran like crap!
Borrowed some jets from the 400f carbs that its not using...
Went from 70 to 75 main jets
Went from 35 to 40 slow jets
Fiddling with # of turns out... It seems to like 1 3/4
Anyway, pulled a long hill at 85 no problem, revs clean all the way thru, still needs a bit of choke for the perfect range, and has a higher idle than prefered.  Runs very well tho, aside from that.
Offline Freaky1
Re: Pods Thread
« Reply #519 on: March 11, 2012, 06:56:24 am »
73 cb350f
4-2 pipes
Gotta Love that heavy air!
Offline andrewk
  • doin' it.
Re: Pods Thread
« Reply #520 on: March 11, 2012, 04:19:30 pm »
IMO
I agree that most people that talk about doing this haven't done the necessary testing required to ensure that the AF ratio was correct throughout the range, but I don't think that means it can't be done.
In my experience, the people who are doing it right rarely have enough time or care to talk about it on the internet.
However, I also agree that for 95 percent of people, pods are unnecessary and will only hold you back.
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
Re: Pods Thread
« Reply #521 on: March 18, 2012, 02:11:00 pm »
am running emgo pods, Jardine turnouts, stock engine and ignition, 086A carbs.  engine is very strong throughout the rpm range, including a WFO run from 50 to 75mph today in top gear.  wants to keep pulling but i ran out of road and nerve.  i hope to attend one of those "dyno dayz" this summer so i can see if my "seat dyno" is accurate.
i'm not sure why the bike is running so well.  i have an idea that running pods with a relatively restricted full length exhaust and also keeping the side covers on makes it a little easier than pods/open exhaust/no side covers.
here's what workin' for me, at 0 to 2000ft el:
76 cb750k (stock engine and ignition)
full tune up just done (carbs bench-balanced only)
emgo pods
jardine full length exhaust
086A carbs (stock)
slows -- 40
mains -- 110
27201 needles (no idea if these are stock)
needle clips in 2nd position up from bottom
air screws -- 1 1/4T
i'll do some plug chops at various rpms if anyone is interested
searching for a dr350se
Offline wildrum88
Re: Pods Thread
« Reply #522 on: March 18, 2012, 02:36:09 pm »
anyone know of some pods that have a 60mm opening but are 2.5" long? i need some really short ones to fit in my bike, I'm running some k&ns that are basically two pod filters connected together and they are a pain in the a*& to get in when doing carb work. Much appreciated!
Offline heffay
Re: Pods Thread
« Reply #523 on: March 18, 2012, 03:26:53 pm »
the only reason to use pods is to make it easier to R&R the carbs...
you're doin' it wrong.   ;)
Offline Freaky1
Re: Pods Thread
« Reply #524 on: May 10, 2012, 03:36:53 pm »
I plan to run K&N pods this time around. I went with UNI's last time and after having to deal with making sure I had (1) enough filter oil as the last time I oiled them, (2) evenly applied the oil, and (3) a way to get that crap off my hands I'd had enough. I'll stick with pods but no more oil.
