Author Topic: My new drag bars hit my tank :(  (Read 2962 times)
Fillmore Slim
« on: April 25, 2007, 11:19:27 PM »
Does anyone know a somewhat easy way to lessen the turning radius on my handlebars. It's on a '72 CB750.
Offline scunny
  • don't call me expert
Re: My new drag bars hit my tank :(
« Reply #1 on: April 25, 2007, 11:26:54 PM »
can you clamp something to the steering stop, or drill them and put in a bolt ?
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Fillmore Slim
« Reply #2 on: April 25, 2007, 11:35:36 PM »
I can't think of a secure way to clamp something on the stop, but drilling and tapping the stop may be possible. It's not very big though, so I could probably only fit a smallish machine screw in it. Thanks for the idea, I'll take a look at it again and see if its feasible.
Dr Rockso
« Reply #3 on: April 26, 2007, 02:41:21 AM »
i just use my welder and tack a bead on the stop , if you do too much hit it with a file , problem solved
Offline KB02
« Reply #4 on: April 26, 2007, 04:50:49 AM »
... or drill them and put in a bolt ?
That's what I did with my bike, Drilling the hole and tapping it was fairly easy. actually getting that little screw to thread in was a pain in the a$$.  :)
One thing to keep in mind: If you do this, it will effective make your handlebar lock not work unless you adjust the tab for the lock. Just FYI.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #5 on: April 26, 2007, 06:05:43 AM »
Slip a small piece of rubber hose over the steering stop, that works well.
Sparty
1972 CB750 K2 Cafe' Style
upperlake04
« Reply #6 on: April 26, 2007, 06:45:39 AM »
 I JB Welded two 3/16"  shaped steel pucks to the stops to prevent the fat non-stock fork ear tubes from hitting the tank. When the stock ears went on, the pucks were easily removed with a cold chisel and hammer.
Online andy750
« Reply #7 on: April 26, 2007, 07:33:41 AM »
Even easier is to get the small chrome clamps (plumbing ones from any hardware store), slip them over the steering stop and viola - no more bars hitting the tank! Works for me on CB750K2 with cafe bars.
cheers
Andy
Offline Chris Liston
« Reply #8 on: April 26, 2007, 08:16:53 AM »
Do this.  works perfect for my clip-ons.  They were the smallest hose clamps the hardware store had.
1976 CB550F Cafe in progress
Offline paxtonpony
  • Up the Irons!
    • My Pics
« Reply #9 on: April 26, 2007, 08:48:04 AM »
Mine's an F0 so this might not mean anything but I just adjusted the angle of the bars until they just barely cleared the tank.  They're about flat if you look from the front.  The F tank might be skinnier at the front though and it's real close on mine.
1969 CB750K - Wrecked
1978 CB750K - Sold
1992 GS500 Streetfighter - Sold
1975 CB750F - Sold (sniff, sniff)
1994 VFR750F - Sold
1990 GSXR 750 - Sold
1999 CBR1100XX - Sold
2000 Triumph Legend TT - Bike of the week for me?
1992 Mustang - Paxton powered (12.02@115mph on street tires) and For Sal
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #10 on: April 26, 2007, 09:23:57 AM »
i've done this with a small bolt slipped in the stop side to further decrease the radius.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Online andy750
« Reply #11 on: April 26, 2007, 12:05:36 PM »
I did exactly what Chris Liston did - easy fix!
cheers
Andy
Fillmore Slim
« Reply #12 on: April 26, 2007, 11:25:13 PM »
Thanks Andy and Chris for the hose clamp idea! I don't have access to a welder so this is just the kind of recommendation I needed. I'll try it tomorrow to see if it solves the problem. Thanks to everybody for your advice, I knew you guys could help.  ;D
« Last Edit: April 27, 2007, 01:15:41 AM by Fillmore Slim »
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #13 on: April 27, 2007, 12:25:05 AM »
Very...uh...Industrial looking
Can't wait till Terry sees these ;D
