On the hondamatics, here is no shift, you have high range and low range, low range is used for lower speed riding, and high range for faster cruising, no actual shift involved other than selecting the range, unlike a car where the range is a subset of the gears in the transmission (drive is all gears, 2 is 1st and 2nd, L is 1st only) with the hondamatic you have two gears in the transmission (planetary gearsets) one high and one low, the lever only selects the range.
all ruduction is done in the torque converter, so there's not any mechanical shifting involved. when everything is in sync, engine speed and cruising speed are right the TC pretty much becomes a 1:1 linkage, if you start losing speed like going up hill, or accelerating, the tc starts acting as a torque multiplier again and essentialy 'downshifts'.
Can't find it now, but there was a writeup on riding the automatic, that gave a rough 'speed' table for the ranges
if stop and go, or slow (around or under 40) use low range, otherwise use high range. I actualy think that low range is good over 50mph, but not sure what the actual top is, and think high is ok for driving in town, just puts motor in a better operating range.
Ken.
