Author Topic: rear sprockets  (Read 1886 times)
Buffo
rear sprockets
« on: June 21, 2005, 08:05:46 PM »
my bike, the famous 1978 CB750K8, came with 2 rear sprockets. one is a Sunstar 405 with 41 teeth. It looks like a stock sprocket. The other spocket says  Esprit and has the numbers 972241 under the name also with 41 teeth. The esprite sprocket however is solid, the only holes in it are the 4 bolt holes. I think this may be the replacement sprocket for the sunstar one.
I havent seen many without holes.
Is this a good name in sprockets?
How can i tell if a sprocket is worn out?
dON
« Last Edit: June 22, 2005, 07:41:40 PM by Buffo »
Offline oldbiker
  • I HATE RAIN
Re: rear sprockets
« Reply #1 on: June 22, 2005, 02:38:30 AM »
Just look at the shape of the teeth. If there is any sign of hooking (ie. hollowing in the face of the teeth), then it is worn out.
Offline jbailey
Re: rear sprockets
« Reply #2 on: June 22, 2005, 07:07:09 PM »
I know the Honda 750 represents the dawn of the superbike era, but didn't realize it began in 1798!
1975 Honda CB550K
2005 Kawasaki ZG1000 Concours
Offline Bob Wessner
  • "Carbs Suck!"
Re: rear sprockets
« Reply #3 on: June 22, 2005, 07:44:55 PM »
Offline oldbiker
  • I HATE RAIN
Re: rear sprockets
« Reply #4 on: June 23, 2005, 12:15:00 AM »
Hey jbaily, your dislexia is showing.
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
Re: rear sprockets
« Reply #5 on: June 23, 2005, 05:10:34 AM »
Buffo
hey there you can also put the chain around the suspect sprocket and try to pull the chain away from  the teeth  the less it moves the better the sprocket good luck
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
Offline oldbiker
  • I HATE RAIN
Re: rear sprockets
« Reply #6 on: June 24, 2005, 01:04:15 AM »
Trying tp pull the chain away from the sprocket is more a test of chain wear than sprocket wear. Any way if either is worn enough to need changing then it is advisable to change them as a pair.
Offline Quail "Owner of the comfortable k8"
  • Now thats good eaten!!
Re: rear sprockets
« Reply #7 on: June 24, 2005, 07:13:15 AM »
Hey if you want to compare it to a worn out one, just buy one off ebay that states: vintage/orig/looks good/shows a little wear, in the discription.  Then you will have a worn out sprocket to compare yours to.
These wonderful little birds are great flyers, delicious eating, excellent for training your hunting dog, and just fun to shoot,or stuff and keep around the house.  Bobwhites can be put with other types of Quail and have very large penis's.  Quail are very popular with the babes.
Buffo
Re: rear sprockets
« Reply #8 on: June 24, 2005, 03:40:43 PM »
Thanks guys.  I Dont see any real wear at all on the older (sunstar) sprocket. No metal is wore off of the teeth and nothing looks rounded.
The only real difference on the new sprocket the teeth are pointed at the top. The older one doesnt have pointed teeth, they are flat but not worn down. it looks like it was made that way.
It seems that i got 2 good sprockets. :D
Don
