Author Topic: CB750 front end on a CB450 ?  (Read 4857 times)
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« on: April 30, 2007, 01:45:46 PM »
Afternoon,
As the topic states I want to put a dual-disc setup on my CB450, and am thinking the easiest way is to swap the fork tubes/lower legs/wheel offa CB750 onto my CB450. Both run 25mm fork tubes, so I really don't see an issue.
Anyone give me some insight on issues I might have while attempting to do this ?
Are the CB750 fork tubes longer than a CB450 (I am guessing they might be).
Can I just swap lower legs and keep the stock tubes (CB450 tubes into CB750 lower legs) ?
Should I just keep what I have and add another rotor/caliper ?
As usual , all help is greatly appreciated... ;D
Offline mrbreeze
  • Not your average
Re: CB750 front end on a CB450 ?
« Reply #1 on: April 30, 2007, 09:47:19 PM »
Get the shorter tubes from cycle x. You're not thinkin of putting a 21" wheel on this one too are ya? If yes,you probably want the longer tubes. We know you'll get it figured out either way.
MEMBER # 257
Offline ProTeal55
  • Est1968.com
« Reply #2 on: May 01, 2007, 06:00:15 AM »
But I think if I go with CB750 fork tubes/wheel/brakes and so on I will have to change the triple tree's as well. I think the CB750 triple-tree's have a wider spread, thus an issue...
What to do...?
Offline hahnda
  • lskdfhs;dljksa;
« Reply #3 on: May 01, 2007, 07:57:27 AM »
The 450 uses the same bearing sizes on the stem but the one problem is that the 750 stem is about 1 inch longer. You could remove the 750 setm from the tress and replace it with the stem from from the 450 and then bolt the entire 750 front end right on. Or you could take 1" or whatever the difference is out of the CB750 stem. Cut it in the middle, remove the difference, have a slug turned to match the inner dia of the stem and weld it back up.
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline ProTeal55
  • Est1968.com
« Reply #4 on: May 01, 2007, 08:01:27 AM »
Seems like allot of work.
Can't I just add a 2nd CB450 caliper and rotor like on did my my CB750 ?
Offline hahnda
  • lskdfhs;dljksa;
« Reply #5 on: May 01, 2007, 08:11:15 AM »
Not sure you can add another caliper on the 450. Is there the holes in the fork to add it?
I am pretty sure you could put CB750 fork lowers on your current fork.
you wold have to measure the distance between the forks if you just wanted to swap the entire cb750 forks, tubes and all to the 450.
Just measure and check everything. You have both bikes.
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline ProTeal55
  • Est1968.com
« Reply #6 on: May 01, 2007, 08:33:35 AM »
I do indeed  ;D
This guy on another board said he just swapped on CB750 lower legs for his dual disc setup-->
I have an email out to him to try and figure this out...
« Last Edit: May 01, 2007, 08:58:32 AM by ProTeal55 »
