Author Topic: CB400F Light Swap...  (Read 1514 times)
jlells01
« on: April 30, 2007, 02:27:38 PM »
Don't have any pictures yet, but I just wanted to pass on some info...
As I continue to "fix-up" my recently acquired CB400F (now it's official, with tags, title, registration, etc, etc...), the next thing on my list was replacement of the factory headlight...a Stanley unit, with a little white/red "DOT Honda" sticker on the back!
It still worked, but riding with it at night was akin to holding a candle in front of you (minus the dripping wax  ;D), so after researching on the forums here, I came across some posts by "DrMark" mentioning that a H6024 light would work just fine in place of the O.E. unit.
So off to Wal-Mart I went...and only $9 later, I was walking out of the store with this model:
http://tinyurl.com/yworyn
According to my specifications, the stock unit had a rating of 35w/50w, whereas the new model is 35w/65w...
Tested at install, and it appears to be working perfectly! Won't been able to see how it does out on the road for a few days though...  :(
« Last Edit: April 30, 2007, 02:30:20 PM by jlells01 »
Offline Frrrrunkis
  • Southern Fried Pest
Re: CB400F Light Swap...
« Reply #1 on: November 09, 2007, 04:03:51 PM »
any updates on how well it works? My low beam just blew and I'm looking around for a replacement
1975 CB400F - "Ol' Red"
Opie & Anthony - Spread the Virus!
my bike pics - http://www.flickr.com/photos/10057704@N05
or http://www.bikepics.com/members/frrrrrrunkis/
If it appears that I don't know what I'm talking about or doing in this post, I more than likely don't
amemoryoncelost
« Reply #2 on: November 09, 2007, 08:27:20 PM »
 Are there going to be any charging issues? I was always under the understanding that the 400f was right on the line as it is, adding anything more would only put a drain on it, right? There was just a long thread about this in the 400f yahoogroups
Offline vames
« Reply #3 on: November 10, 2007, 12:30:28 PM »
Doesn't your 400f have the dreaded 6 1/2-ish inch headlight bucket? If so, how'd you fit a 7 inch headlight?
Offline GroovieGhoulie
  • I have to return some videotapes.
« Reply #4 on: November 10, 2007, 01:17:18 PM »
+1.
It's like some weird 6 3/8" or something isn't it?  That's the big rub, finding a damn aftermarket light that'll fit.
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #5 on: November 10, 2007, 01:34:56 PM »
+1.
mine has a Cibie unit with an adator ring, never stripped it to find out what this involves but I believe it was a common modification in the 70's
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline dave400
  • Super Lamb Banana
« Reply #6 on: November 10, 2007, 02:45:55 PM »
You can make anything fit with a bit of ingenuity I’ve got a 5 ¾” car unit Cibie H4 lamp on my 400 by making an extra fitting ring and it’s bright! I’ve had no charging issues.
Cheers
Dave
Offline vames
« Reply #7 on: November 10, 2007, 02:51:18 PM »
Very interesting. I'm thinking about just getting some aftermarket chrome ears and a 7inch headlight for mine. I don't have blinkers in the front and it just might clean up the whole front of the bike.
Offline vames
« Reply #8 on: November 12, 2007, 06:01:38 AM »
FYI - you can get 6 3/8" reflectors that take H4 bulbs from www.candlepower.com
They also have a 35/35 H4 bulb that I hear is plenty bright and won't bust your bike's electricity budget.
Offline 333
  • Time for change
« Reply #9 on: November 12, 2007, 07:06:31 AM »
FYI- Car bulbs and M/C bulbs are not the same.  The light is reflected in a different pattern.  The pic that Dave400 posted shows how-  that pie shaped part of the glass from 8:00 to 9:00.  And remember, bikes are a little higher off the ground, and have to rely on only one bulb, so that answers the "why" question.  I've run a 55/60 for years with no charging issues, but I don't burn it during the daytime.  The Candlepower is very good, but also the only game in town these days
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
