Author Topic: Who runs a 520 chain on a CB750?  (Read 11659 times)
Offline Kamal
  • "..but, how did it make you FEEL?"
    • MotoTherapy
« on: April 30, 2007, 07:06:51 PM »
Sorry if this is a moot point.
Chains are so strong these days!  Does anyone run 520 chains on CB750 bikes?  Does anyone RACE with them? I think I have been trail riding on my dirt bikes too long....I've got 520 chain fever!
Thanks!
Kamal
« Last Edit: May 01, 2007, 11:28:02 AM by Kamal »
CB750K6
CB750K2 Drag Project
IT465 Yammie
KMX250 "Kawazuki" (or was it a "Suzusaki"?)
Offline merc2dogs
Re: Who runs a 520 chain on a CB750?
« Reply #1 on: April 30, 2007, 08:12:14 PM »
I replaced my chain with 520 3 years ago, no problems plenty strong for the cb.
 Don't race, but tend to get carried away
Ken.
Offline turboguzzi
« Reply #2 on: May 01, 2007, 03:02:48 AM »
running a 520 in my CB500 racer with ally rear sprockets / steel front sprocket
no problems so far but bike sees only track time
Would go with steel rear sprockets if aplying to a street bike.
You'll have to drill your own blank sprockets to suit your wheel and grind the front sprocket to suit the narrow 520,  that's what I had to do in mine. And pay attention to offsets so chain runs straight
With all the work needed and shorter chain life, got to wonder about the worth of 3-4 lbs weight savings on a street bike.
my two cents
TG
« Reply #3 on: May 01, 2007, 06:03:12 AM »
 The 520 will work out very well. These people can make any size sprocket you want  www.sprocketspecialists.com
Offline Kamal
    • MotoTherapy
« Reply #4 on: May 01, 2007, 09:29:13 AM »
I think I discovered, while restoring my 82 Yamaha IT465, that the front sprocket for this bike (same as a KDX200 as well) fits right onto the CB750 output shaft (though doesn't have any tapped holes for the retainer.
Ill double check on that today.  I'm willing to bet there are other dirtbike rear sprockets that would be a match...I'll do some research!
Kamal
CB750K6
IT465 Yammie
Offline tinyrobot
  • Mock it up before you Fock it up!
    • ChiVinMoto
« Reply #5 on: March 04, 2008, 01:42:01 PM »
Bump for anyones updates.
I'm looking to convert the 630 to 520 on my 78k cb750.  Anything to watch out for or is it just swap out for new sprockets?  I read that I might need a spacer in a 630-530 conversion, so I assume the same might apply hear.
Offline BlindJoe
« Reply #6 on: June 06, 2010, 07:43:42 AM »
bump.
has anyone tried the kit from cycle-x? http://www.cyclexchange.net/Chain%20Sprocket%20Page.htm
Offline HawaiiMike
    • Hawaii realtor
« Reply #7 on: June 06, 2010, 04:30:38 PM »
I wonder if the Cyclexchange set will work on a CB550 too?  Looks like it will fit.  Maybe need a smaller sprocket for the back wheel.
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
« Reply #8 on: June 06, 2010, 04:52:05 PM »
Kamal and Tinyrobot,
I run a 530, not 520 on both my 750's. It is a straight swap, just your new chain will have a few extra links in it, compared to a 630. The links are smaller in length and width, so you need more to span the distance between sprockets. I don't have either one here now to look at, but memory says 17/48 on the sprockets.
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
Offline B.O.X.N.I.F.E.
  • The Stumped
« Reply #9 on: June 06, 2010, 06:09:47 PM »
No luck here. I've seen them recommended several times and traded emails with Dee Dee in their sales department. She recommended a steel front and aluminum rear, with an o-ring chain for my 550. I let her know about the 550's o-ring incompatibility and that their catalogs 12-16 tooth front sprocket listings wouldn't support the stock gearing for the 550, which is 17 teeth up front, and inquired about having a 17 tooth front made or added to the catalog. At that point she started ignoring my emails. I tried two more times with no response. I was eager to buy them too...  ???
1974 CB550
Forever West
Offline jaguar
« Reply #10 on: June 08, 2010, 06:08:47 PM »
sooo will a 520 hold up to the HP of a 750?
Offline I Zombie
« Reply #11 on: June 08, 2010, 07:59:36 PM »
bump.
I got one of there set ups, yet to install it but it looks damn good
78 CB750K
Offline Ricky_Racer
« Reply #12 on: June 08, 2010, 09:27:28 PM »
Dude! RC51's run 520 chain conversions. No problemo with our dinosaurs!  RR
Offline jaguar
« Reply #13 on: June 09, 2010, 05:47:21 AM »
i did not know that....thanks
sounds good
alloy rear sproket and 520 chain here i come.
no to figure gearing.
is there a chart that shows gearing?  but takes into account HP?
so at a given hp you can tell how gears will work?
Offline BrianAdair
  • Oh, so this is where you type the text...
« Reply #14 on: January 06, 2011, 08:27:58 PM »
Dragging this thread back up.... ;D
I was thinking of going with a 530 set up, the local guy I get most of my NOS parts is trying to talk me into staying with the 630 set up.
His reason, he says the 530 will end up busting the engine case, and to small for what I have done to the engine....?
Didn't the 76 back 750's come with a 530 setup?
Mine is a K7 model, I have bored it over, larger cam, springs, 4 2 1 headed, ported head. I just don't see the need in the big bulky 630 chain?
What are the advantages disadvantages to this?
Offline Gordon
  • 750K1, 550K2
« Reply #15 on: January 06, 2011, 10:43:57 PM »
I think your local guy is stuck in the 70's.  Any decent, modern 530 chain is plenty strong enough.
« Reply #16 on: January 07, 2011, 01:09:58 AM »
+ 100000
New chains don't even resemble 70's chewing gum chains..... ;)   630's rob horsepower and are a big chain, not needed any more. Modern race bikes use 520 and 530 chains....Far more power than our little beasts.....
Offline Spanner 1
« Reply #17 on: January 07, 2011, 05:38:53 PM »
So, a 530 will work to replace a 630 (750-K8 ) chain without any mods. except the 530 will have more links ??
« Reply #18 on: January 07, 2011, 05:48:30 PM »
Need sprockets as well....
Offline BrianAdair
« Reply #19 on: January 07, 2011, 06:08:47 PM »
I'm having trouble finding a source for sprockets.. ???
Wheres a good place to get 530 sprockets that will work on my K7, I'm not wanting to stay with the stock gearing 15 41, thinking of going with a 14 46 for more low end.
this is a neat site  http://gearingcommander.com/
Offline Spanner 1
« Reply #20 on: January 07, 2011, 06:13:44 PM »
Sorry the Poms are kickin' yer arses in the Cricket, Retro  ;D
« Reply #21 on: January 08, 2011, 07:38:56 PM »
Had to happen sooner or later, no one can be NO1 for ever..... ;)
« Reply #22 on: January 08, 2011, 08:21:01 PM »
 Brian, I would not run less than 17 T for High hour usage.
 18/48 is stock...17/48 will get off the line better..
Offline BrianAdair
« Reply #23 on: January 08, 2011, 08:58:03 PM »
Sent you a PM, Frank.
