Author Topic: Hello from the South, North Carolina.  (Read 1113 times)
holdfastgreg
« on: May 01, 2007, 06:53:17 PM »
Hello there.
About me:  I'm 22, live in the Triad of NC and as most of you I am a gear head.  I build and collect vintage bmws and I am apart of Vcca and BMWcca.  I am currently building a '78 cb750 which I picked up a little over a week ago.  The frame wont see paint till the winter but in the mean time I should have a good 60% of the bike restored by the end of May.  Everything from new bars, levers, switches, harness, fuse block/tray combo, seat and so on.  Paint will be shot on the tank/seat and maybe the side panels if I dont decide to go with a naked bike theme.  Anyways, I figured Id drop in and say hi!!!
Offline Bob Wessner
  • "Carbs Suck!"
Re: Hello from the South, North Carolina.
« Reply #1 on: May 01, 2007, 06:55:24 PM »
Hi back at you. Don't forget to post a pic after your done.
Offline dusterdude
« Reply #2 on: May 02, 2007, 08:37:49 AM »
welcome
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Xnavylfr
« Reply #3 on: May 03, 2007, 04:50:27 PM »
Welcome , I did live in Kville and worked at TIMCO at the gboro airport. I now live over at Jacksonville,nc. I have a 78 sohc on a savior frame. If you need some parts I have a full garage and mostly for the old Hondas
holdfastgreg
« Reply #4 on: May 05, 2007, 12:21:35 PM »
Well it looks like our paths have crossed sometime or another.  For starters, my dad served 30 years in the Marine Corps and subsequently I grew up in Jacksonville.  He had a 3yr detail in greensboro commanding reservists and fixing problems so I ended up permanently here in Greensboro.  A company I worked for would doing race components and composites would often steal employees from Timco.  Im far to familiar with both aspects youve mentioned.  As far as parts go, I need a lot of stuff unfortunately.  Ive spent a lot of money this week buying parts for the bike.  I've managed to buy switch caps, switch housing, master cylinder(x2) and 2 levers from a 11/16th harley fitting 7/8th bars, twist throttle with grips, new wiring harness and fuse box/battery try and some other items.  I d like to find a 4-2 or even just a 4-4 header, though I can make one I'd prefer to just buy one right now.  PM me with stuff you have.  I'm just looking for everything, i might even need a new set of carbs...mine look bad.
