Author Topic: Needle jet removal ?  (Read 3839 times)
RDRF3
« on: April 06, 2005, 07:14:27 AM »
  how do you get the needle jet out of the carb body ?
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
Re: Needle jet removal ?
« Reply #1 on: April 06, 2005, 07:32:30 AM »
What bike  ???
In the UK anything over 40 years old only needs insurance and Fuel.
RDRF3
« Reply #2 on: April 06, 2005, 10:01:36 AM »
   Sorry AGAIN  !!!  ,  1970 750K0
   Are they pressed in or WHAT ???
   Thanks for any help you can give !  Raymond in Texas
x2qwk4ux
« Reply #3 on: April 06, 2005, 12:58:25 PM »
I have only gone through a set of K1 carbs, and those wrenched out with an 8 or 7mm wrench.  I think they're called emulsion tubes...should have horizontal holes in them.  I've been through lots of CV carbs that have the jet-needles simply pressed in...well...they actually fall out once the emulsion tube if removed.  Sometimes you have to pry them out from the carb-throat area with something soft...like a rubberized set of pliers handles.  Either way, replacing them made a hell of a difference on my old bike.
Good luck
jsaab2748
« Reply #4 on: April 06, 2005, 06:25:13 PM »
After you unscrew the main jet and the emulsion tube as an assembly you'll have uncovered the needle jet, if memory serves me. Get a length of 5/16 inch wooden dowel about the length of a new pencil and sharpen it slightly
(not too pointy) in a pencil sharpner. Using the dowl as a driver, lightly tap the jet downward and out of the carb body.
jsaab2748
« Reply #5 on: April 06, 2005, 06:50:38 PM »
Better clairify: the jet is pressed in  from the BOTTOM of the carb. Install the dowell thru the TOP of the carb and drive jet downward out of carb body. sorry to confuse.
