Author Topic: !977 CB750F2 Master Brake Kit  (Read 1735 times)
marcshep
« on: June 22, 2005, 10:25:10 AM »
Greetings all,
I have been working on my beast for a while and have ran into an issue where the front brakes will pump up and lock, the only way i can unlock them is to use the bleeders to releave some of the pressure. Once i do that it will be fine for a couple of days then it will lock again. I have concluded that it's the Master Brake Cylinder return thats cloggged. Reading on here i have found numerous posts relating to this and quite a few tips on how to get the circlip out. The thing that i have found now is that i can't find a kit to rebuild the cylinder i have. Instead of the round cylinder i have seen at more than one site i have one that is flat on the top with 2 screws holding the top on and it has a sight glass to show the level of fluid. Did some PO take off the original one and put one from another 750 on? or is this a case of there were 2 possible for this bike and i have the one that is rare?
Thanks,
Marc
Offline Bob Wessner
  • "Carbs Suck!"
Re: !977 CB750F2 Master Brake Kit
« Reply #1 on: June 22, 2005, 12:15:28 PM »
Marc,
Don't own one, but found this. Sounds like what you are describing is the stock M/C for the F2.
Offline jtb
  • An unlikely
« Reply #2 on: June 24, 2005, 07:23:37 PM »
Mark, the pdf is for a later model.  The 77 and 78 F's have a round mc with a screw on cap.
John
1977 CB750F
1985 V65 Sabre
marcshep
« Reply #3 on: June 29, 2005, 05:24:33 AM »
Thanks all, looks like the PO did put on a different MC onto this bike. Now for the fun of trying to get a rebuild kit for it
Thanks,
Marc
Offline Six
  • Lucy - CB750F Cafe Racer
    • Motorcycle Diary
« Reply #4 on: June 30, 2005, 10:18:42 AM »
I have a '77K and a '78F model and both have different MC's.  I rebuilt the F-model and noticed the old cylinder had quite a bit of crud built-up around a kind of reed-valve that I guess is how the fluid gets back in to the reservoir when you let go of the lever.  Honda has rebuilt kits for about $38 for these bikes, seems reasonable when the aftermarket kits on Ebay go for around $30 plus shipping.
The circlip was a witch to remove, and it took me a while of grinding and shaping one of my circlip pliers to get them to go all the way into the MC well.
On another note - CBR 600's MC are cheap and plentiful (I got one for under $20 on Ebay) and it works like a charm with my dual-disk Goldwing front-end.
Six - Minneapolis.
