Author Topic: Clutch Problem Cb550  (Read 1510 times)
blackbird
« on: June 22, 2005, 03:33:14 PM »
I have a couple of 550's.  I am right at the end of a 550 cafe project.  Last time I had the bike up,  I put new clutch plates in it.
WHen I rebuilt the clutch, the little actuating arm did not line up with the little notch.  ( no I didn't leave out the super thin shim )
The little arm will start farther engaged than it should. In other words, I don't have enough adjustment in the cables to get the clutch setup like it should on any other bike.  WIth both adjustements all the way out, there is like half a pull of empty before the clutch disengages the plates.
 Its almost like the little barbell is too short???
ANy ideas?
michael
Re: Clutch Problem Cb550
« Reply #1 on: June 23, 2005, 01:55:19 AM »
Read the manual on clutch adjustment, with new plates you have to adjust the nut and screw at the bottom of the case
