Author Topic: I need a brighter headlight  (Read 2421 times)
qcextreme
« on: June 22, 2005, 05:28:12 PM »
75 CB750F SuperSport, Got to have a brighter headlight, what's eveyone running and where did you get it, This riding by candle light, has to go, I need more light, please help
Offline Bob Wessner
  • "Carbs Suck!"
Re: I need a brighter headlight
« Reply #1 on: June 22, 2005, 05:38:22 PM »
Run a search using "halogen" and there are lots of posts on this. Generally speaking, a good move "for a brighter tomorrow"  ;)
Offline jbailey
« Reply #2 on: June 22, 2005, 06:51:06 PM »
I just went to advance auto and bought a 7 inch headlight part number H6024.  Works great, and costs under $10.
1975 Honda CB550K
2005 Kawasaki ZG1000 Concours
Offline Jonesy
  • Shop Rat
« Reply #3 on: June 22, 2005, 08:24:36 PM »
JC Whitney sells an H4 Halogen upgrade kit for $20. It features a replacable bulb and accepts the stock wiring harness. I got one and I love it! ;D
carsholduptraffic
« Reply #4 on: June 23, 2005, 05:43:13 AM »
bulbs are easy to replace, but take care with the wattage. the old k2 runs a 75/55w, but that is the limit for it. 100w was too much for the electrics, let alone the reflector.too hot. the problem in old bikes is the general condition of the harness, with connections the main faults. careful dressing of the bullet connectors with fine wet & dry paper- all mating surfaces- will help you will find the biggest gain for least $$$ here. protect the connectios from corossion. tape stops electrical contact, not moisture. spray on lanolin is the best protcector i've seen so far for waterproofing electrics in a motorcycle application. it is made from wool grease, a sorta kiwi k.y.  it works for many things. ask a kiwi.
high wattage equals high load, and may not leave enough to charge the battery, if you use the headlight a lot. \
Offline DrMark
« Reply #5 on: June 23, 2005, 08:29:01 AM »
JBailey....which H6024 did you buy from Advance Auto? The Sylvania H6024 comes in 4 configurations based on wattage output. Then there are several other brands at triple the cost. Thanks. Dr. Mark
1978 CB550K
1983 CB650SC Nighthawk
Offline MikeDeB
« Reply #6 on: June 23, 2005, 12:27:12 PM »
I'm running Hella fixtures on both 750's with PIAA Extreme White Plus H4 bulbs.  Very bright and the charging system of both bikes handles the lights with no problems.  Paid around $30 or so for each fixture.  I got the Hellas from this place:
http://www.rallylights.com/
Mike (Old SOHC/4 #2641)
Holt, MI
71 CB750K1
72 CB750K2
72 CB100K2
97 Ducati 900 SS/SP w/FCRs
98 Ducati 750 Monster w/FCRs
80 SR500
"Growing older is inevitable, growing up is an option."
Offline dusterdude
« Reply #7 on: June 23, 2005, 12:31:38 PM »
mark,i thought the h6024 was supposed to have no more than a 55w high beam.that is supposed to be the law,i thought.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
eldar
« Reply #8 on: June 23, 2005, 12:59:34 PM »
I look at it this way. Cars have 2 - 4 lights. We have a big fat 1 light. Oh ah. Upping our wattage may not be completely legal but again we only have 1 light and what about the new HID lights that could blind a blind person. If you are concerned about your charging system, swap the signal lights and tail for LED bulbs. Uses about 1/10 the power. Also there is a section here that shows you how to juice up your regulator a bit.
Offline jbailey
« Reply #9 on: June 25, 2005, 08:04:49 PM »
I just bought the standard H6024.  It is brighter than the original, which I still have.  I just checked the sylvania website and see they make a few that are rated at 65w.  Those should work.  It's all a matter of how much you ride at night and how much you want to spend.  I only ride at night when I accidently don't make it home before dark.
1975 Honda CB550K
