Author Topic: Left Upper Rear Shock Mount Bolt Needed  (Read 5518 times)
Offline DrMark
« on: April 06, 2005, 07:32:11 AM »
OK.....I did something dumb this AM. I was doing a check of all the bolts and fittings before my first ride of the season. I stripped out the Left Rear Upper Shock Bolt and Nut on a 1978 CB550. Does anyone have an extra bolt and a set of matching dome nuts. I'm going to have that bolt professionally changed, but I need the parts first. Any assistance would be greatly appreciated. Dr. Mark
« Last Edit: April 06, 2005, 08:23:58 AM by DrMark »
1978 CB550K
1983 CB650SC Nighthawk
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
Re: Left Upper Rear Shock Mount Bolt Needed
« Reply #1 on: April 06, 2005, 07:36:16 AM »
You don't say what bike but this bolt is normally part of the frame itself, you could probably cut it off drill out and insert a replacement threaded section but you wont be able to buy a stock part. I'd start with getting a new acorn nut and then some threaded rod to fit that.
In the UK anything over 40 years old only needs insurance and Fuel.
Offline mcpuffett
« Reply #2 on: April 06, 2005, 02:45:32 PM »
hi how about just getting a new thread put on there ?, before you start cutting bits off worth a try .
« Reply #3 on: April 06, 2005, 11:02:51 PM »
I had  a similar problem on my CB750K3, a PO (the bastard!) cut a large part of the threaded portion off the end of each stud on my upper shock mounts, so I cut them both flush with the shock mount itself, drilled (and drilled and drilled, that steel is HARD!) the mountiing boss out and tapped it for 10 x 1.25mm thread (you can't buy threaded rod in that size apparently) instead of using a couple of 10x1.25mm bolts with their heads cut off I just threaded the bolts straight in with the grab rail and a couple of stainless plain and spring washers to stop them from winding out.
They look really good, and honda should have done it from new, because fitting new shocks is now a piece of piss! All I do is line up the clevis mounts on the swingarm, loosely thread that bolt in, then slide the top shock body mount over the mounting boss on the frame, then fit the grab rail, thread in the bolts etc, tighten it all up and it's done, no swearing or cussing required. Cheers, Terry. 8)
