Author Topic: Two cylinders not firing at low RPMs  (Read 1391 times)
Offline sparty
  • I just play one on TV
    • Gallery
« on: May 05, 2007, 05:45:46 PM »
Guys,
My friend has a 4 cylinder bike and two of the cylinders do not fire at low rpms.  As the rpms come up, all of the cylinders fire.  The carbs are getting fuel to the cylinders, but there seems to be a spark issue at low rpms.  What could be the cause?
Sparty
1972 CB750 K2 Cafe' Style
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: Two cylinders not firing at low RPMs
« Reply #1 on: May 05, 2007, 05:49:08 PM »
Sooty plugs.
Crappy coil.
Other stuff.
Sooty plugs will do that for sure, though.
No.
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: May 05, 2007, 05:51:02 PM »
Have you checked to see if it's a spark issue, or are you just guessing?  It could be a low speed jet issue in the carbs.  What kind of bike is this?
Offline sparty
    • Gallery
« Reply #3 on: May 05, 2007, 05:54:48 PM »
Sooty plugs.
Crappy coil.
Other stuff.
Yeah, I told him I think it is a coil issue.  I pulled his plugs and they seem fine.  BTW it is a  1976 GS750.
Sparty
Offline sparty
    • Gallery
« Reply #4 on: May 05, 2007, 05:57:42 PM »
It has got to be a spark issue.  I pulled a plug and put it on the head with the wire attached.  I cranked over the starter and I saw no spark.  But it must spark at higher rpms, because you can hear and feel the two dead cylinders come to life.
Sparty
Offline keiths
« Reply #5 on: May 05, 2007, 07:48:01 PM »
Could it be a weak battery? Once the rpms come up the voltage comes up too.
« Reply #6 on: May 06, 2007, 01:46:54 AM »
Didnt the 75 have points ignition? If so are they set right?
