Author Topic: Dealing with Rust and Chrome  (Read 20723 times)
Offline m00ntan
Re: Dealing with Rust and Chrome
« Reply #25 on: July 27, 2007, 09:57:07 AM »
The phosphoric acid just gets poured back into jugs until the next use.  What I want to get rid of gets sprayed on anything outside that can rust.
CB750K4
CB550K1
CM400C
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #26 on: July 27, 2007, 10:04:29 AM »
How do you guys dispose of the acid? I don't really have any garage drains or anything like that.  Is it safe to pour on soil?
If you really must dispose of it, do you have a hazardous waste disposal facility nearby? Don't dump it down any drains. You can neutralize it with baking soda.
ZetecOwns
« Reply #27 on: July 27, 2007, 02:38:43 PM »
I'll check on the waste disposal. I'm shooting for a good sized container full (5 gallons water, 1 gallon acid), so it won't be the easiest thing to pour into jugs. I'll be sure to neutralize it first.
Thanks for the information.
« Reply #28 on: July 27, 2007, 07:39:39 PM »
Home Depot with the paint thinner.  Klean-Strip Phosphoric Prep & Etch, $13.75 gal,
MFG Model # : GKPA30221
MFG Part # : GKPA30220 .
Thank you, I appreciate that! I'll pick some up and dilute it with five parts water, as Terry recommended. I've got quite a bit of parts that will go in the vat.
If you use Terry's method you must also buy a good quantity of Beer. This way you have some way of occupying yourself during the process. Otherwise you may rush the process and have poor results. ;D
ZetecOwns
« Reply #29 on: July 28, 2007, 08:17:42 AM »
A good quantity of beer, huh? How about five parts beer to one part hour? Just in the name of consistency and all.  :P
« Reply #30 on: July 28, 2007, 12:02:43 PM »
Works for Terry. That is his secret weapon.
Offline m00ntan
« Reply #31 on: July 29, 2007, 09:12:30 PM »
I don't see the point in diluting phosphoric acid.  I pour it straight into aluminum turkey pans and  soak the parts until everything is nice and foamy, ten or twenty minutes.  Then I pour it back into jugs until my next rusty part is ready.   I'm as cheap as the next guy, but I find diluting just confuses me, since it doesn't seem to loose it's properties, and I need to know when it's full strength (allways).
If you need a five gallon tub of this stuff, you should really consider treating one corner of the part at a time.  You can spray too, but it seems to dry before it has time to react.
Whatever is unwanted, give to somebody with one of those Arrow metal sheds or a lot of iron railings.
« Last Edit: July 29, 2007, 09:14:12 PM by m00ntan »
CB750K4
CB550K1
CM400C
