Author Topic: '82 CB750C ignition wire  (Read 699 times)
82CB750C
« on: May 11, 2007, 07:15:54 PM »
Hi all-
Hopefully this will be an easy one for you CB gurus out there.   ;D
I've got an 82 CB 750C where none of the electrical components will work.  No headlight when the key's turned, no ignition, nothing.  So I started digging for anything obvious- blown fuses, drained battery etc etc.
After digging a little further, I found that the plug/wire coming from the ignition switch isn't plugged into anything.  Duh, that's why none of the electrical stuff works.  Easy fix, I think.  WRONG.  For the life of me, I can't find where this plugs in.  Took the tank off to find a connector, nothing.  Disassembled the headlight to see if there's a connector there, nada.
So could someone please take pity on a CB newbie and say where this plugs in?
Thanks!
Offline 750goes
  • it will live
Re: '82 CB750C ignition wire
« Reply #1 on: May 12, 2007, 03:04:15 AM »
try under the ignition key (hopefully there will be a barrel attached) it may plug into that.....
