Author Topic: 650 head gasket on an overbore 500  (Read 1273 times)
Offline hymodyne
« on: May 14, 2007, 06:19:38 AM »
will any year 650 headgasket work on a cb 500 K1 running an overbore kit? I have installed the 605 kit from ebay, and I have been struggling with rebuild issues that have made it necessary to take the head off. I'd like to replace this one with one that will fit properly. will ID on a 650 gasket match or come close enough to those of the odd-size 605 gasket that I could interchange them? otherwise, the sellers of the overbore kit indicate that I would have to purchase a whole new overbore kit just to get a new head gasket.
suggestions are appreciated.
hym
Re: 650 head gasket on an overbore 500
« Reply #1 on: May 14, 2007, 07:59:42 AM »
Hi Mate I scorred some solid copper gaskets on ebay a while back, if i can locate them i might be willing to part with one, they are thinner than the fiber but being solid copper can be annealed and re-used
« Reply #2 on: May 14, 2007, 09:50:29 AM »
Get in touch with Cometic for your gaskets. They are the best out there and can make whatever you need. If your overbore has taken away too much area between cylinders for a standard type gasket they will make a copper gasket for you. You DO NOT need to purchase another kit!
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #3 on: May 14, 2007, 11:41:11 AM »
cometic can make proper gaskets to whatever bore you need in the proper material. i'm told copper gaskets are more prone to leaking.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline cafe75-550
« Reply #4 on: May 14, 2007, 11:54:38 AM »
New bike!
'07 Triumph Speed Triple 1050
Never enough projects!
'75 CB550 "Cafe", '76 CB550 parts bike
'64 Norton Atlas featherbed/'71 Triumph 750 Triple (Triton project)
'68 BSA Thunderbolt (frame and cases, project in the wings)
'57 Triumph Thunderbird (frame and mostly complete engine)
« Reply #5 on: May 14, 2007, 11:56:36 AM »
I agree about copper gaskets being more prone to leakage. I would only use one as a second choice such as with my 1080 engine where there is insufficient space between cylinders for a standard gasket.
Offline dusterdude
« Reply #6 on: May 14, 2007, 12:25:45 PM »
way back in the old days,we would spray steel gaskets with copper coat to keep them from leaking,not sure if it would be necessary to spray copper coat on a copper gasket tho.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
