Author Topic: 750 tank on 550?  (Read 1839 times)
memphis3724
750 tank on 550?
« on: May 15, 2007, 04:30:36 PM »
May be a stupid question but I'll ask anyway.  Would a 750 tank fit on a 550?  Anyone know the difference in lengths?
memphis3724
Re: 750 tank on 550?
« Reply #1 on: May 15, 2007, 05:51:51 PM »
Anyone?
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: May 15, 2007, 05:56:06 PM »
It depends on what you mean by "fit", and it also depends on what years and models of the 750 and 550 you're asking about.
Offline Swede
« Reply #3 on: May 15, 2007, 07:11:04 PM »
I have a 78 750 tank that I fit on my 76 550K.  I thought it would be harder but really it was quite simple.  You need to cut a small portion of the mounting studs off and trim the rubber bushings.  The rear rubber strap didn't mate up so I used a piece of foam for the rear tab to rest on and used a heavy zip tie to secure it.  I also have a 750K tank that I was going to use, it fit but I didn't like the look.  If you fit a 750 tank make sure that the petcock is on the same side as your 550.
memphis3724
« Reply #4 on: May 16, 2007, 01:58:54 AM »
Ok thanks. I was also wondering if a 750 tank is longer.  I was thinking it may be a quick "stretched" tank for a 550.
Offline hymodyne
« Reply #5 on: May 16, 2007, 03:49:51 AM »
it is a "stretched tank" for the 550. to put a 750f tank on my 500K1, I had to shorten the posts on the frame as had been mentioned, and then cue my stock seat pan about 2" in the front to allow for the longer tank. I came up with a mounting system for the rear of the tank to keep it secure. there is a pic of my cafe project in a recent link titled body pics. that post has a pic of the longer tank on my bike.
hym
memphis3724
« Reply #6 on: May 16, 2007, 04:12:32 PM »
Hey hymodyne... are you saying this is a 550 with a 750 tank.  If so... that's really sweet!
http://i113.photobucket.com/albums/n213/hymodyne/100_0886.jpg
Offline hymodyne
« Reply #7 on: May 18, 2007, 04:46:56 AM »
I cut the seat pan on my 500K1 and took a thin rubber hose cut lengthways and ran it around the new cut edge. I'll post some pics of my rear tank mount mods this afternoon.
hym
