Author Topic: Seating New Fork Seals 78 750K  (Read 5431 times)
« on: May 16, 2007, 02:13:12 PM »
When I bought the bike, the front seals starting leaking. It was a few years ago and i was multitasking project. I bought some No Leak seals and yeah they leak ok. I ordered some new Honda seals. I went back through my Honda Shop Manual to referesh my memory. They show a tool for pushing/banging the seal down. Looks like a piece of pipe. What have you guys used?
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: Seating New Fork Seals 78 750K
« Reply #1 on: May 16, 2007, 02:28:28 PM »
A piece of pipe.
Find the correct diameter of plastic (ABS) drain pipe and have at it. Or a big enough socket.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
« Reply #2 on: May 16, 2007, 05:13:32 PM »
A piece of pipe.
That is what I thought Nick. Thanks Bro
Offline nickjtc
« Reply #3 on: May 16, 2007, 08:04:26 PM »
OK Bobby. Who is the babe in the avatar this time??
1977 Suzuki GS750
« Reply #4 on: May 17, 2007, 06:02:34 AM »
Same Honey as last week just a bit less innocent pose.
Offline kuyarico
« Reply #5 on: May 18, 2007, 08:38:13 AM »
I just did mine, and used a pvc pipe fitting as recommended here:
http://www.salocal.com/sohc/tech/frkng/frkng2.htm
quote from salocal.com : This piece of PVC plumbing is perfect for knocking in the seal and won't do any damage to it.  The part number is a HomeDepot tag (C4801-2-7) and can be used to find one just like it.  Other wise, it's a 1 1/2 inch adapter of some sort.
Offline ic455
  • 750 K6
    • My Gallery
« Reply #6 on: May 18, 2007, 05:59:24 PM »
I used the same type of PVC adapter, but mine came from Lowe's and had to be trimmed via Dremel to get the seal in far enough to allow the snap-ring to go back in.  I got the idea from salocal, too.
eldar
« Reply #7 on: May 23, 2007, 12:38:18 PM »
Used my fingers. I dont remember having an issue getting them in, just in getting the fork caps back on after filling oil!
After storage for a few years, they leaked slightly but use has made them seal again.
Offline CB750 SS
« Reply #8 on: June 11, 2007, 06:34:08 AM »
I used a big old socket I had laying around worked perfectly!
« Reply #9 on: June 11, 2007, 07:21:59 AM »
last question, do you bang them down and how far, or do you just push them down till you can get the circlip on.
Offline ic455
  • 750 K6
    • My Gallery
« Reply #10 on: June 11, 2007, 03:11:26 PM »
far enough to get circlip on is what I did.  I think there is a shoulder that the seal bottoms out on anyway.
Offline Bikebuff
« Reply #11 on: July 10, 2007, 01:32:02 PM »
Thanks so much for all the helpful tips!  This is my first time replacing fork seals, so I'm a bit apprehensive (meaning I'd rather do my homework first and at least try to get it right before doing it again).
Finally, will any type of circlip pliers work?
Thanks again!!!
Offline ic455
  • 750 K6
    • My Gallery
« Reply #12 on: July 10, 2007, 07:23:50 PM »
Thanks again!!!
the ones I used were real cheapies, but worked ok
« Reply #13 on: July 11, 2007, 06:04:50 PM »
Actually I turned out using my fingers first and then the old seal as a driver with a small dowel and hammer to lightly seat it. The most important thing is polish the forks, really polish them good. The circlip can be pushed in with your fingers, they are really just a light guage  round spring.
ChefJoe
« Reply #14 on: July 17, 2007, 11:00:04 AM »
are the forks for a 78 f the same diameter?
