Author Topic: Good Idea or Bad?  (Read 1528 times)
Terry L.
Good Idea or Bad?
« on: May 17, 2007, 09:19:52 AM »
With the Bike allmost down to the frame . I am thinking of replacing All nuts and Bolts with stainless and this includes the engines and carbs. Is there any areas that should special attention besides the Carbs. or should i stick with the originals there?
Offline mgmuellner
Re: Good Idea or Bad?
« Reply #1 on: May 17, 2007, 09:55:10 AM »
I dont care about my bikes being original & change them out too.  I also go for allen heads instead of the phillips.  They last longer, look better & are more functional (no stripping).
73 CB750
69 CB350
73 RD350
73 z50 (2 of em)
01 SV650
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #2 on: May 17, 2007, 09:56:41 AM »
Not sure why you would not change the screws holding the carbs together, since there are kits out there.
Anyone else got a comment as to why this should not be done??
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline Green550F
  • Nothing is as cool as that which you made.
« Reply #3 on: May 17, 2007, 06:16:35 PM »
DON'T USE STAINLESS SCREWS IN ALUMINUM! :o
That's a good way to make it a permanent assembly! There is an electro-chemical reaction that will sieze the threads and they will NEVER come out. Guess how I know... ::)
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
Terry L.
« Reply #4 on: May 17, 2007, 06:55:58 PM »
Brain fart here....  ::) .I was just reminded about how many times i have swore when trying to take steel screws out of the older  Aluminium Life boats and how they were turned to dust pretty much.  I know common steel screws will react with aluminum but will stainless? was it stainless you used in your carbs?
Terry
« Reply #5 on: May 17, 2007, 07:08:27 PM »
That's a good way to make it a permanent assembly! There is an electro-chemical reaction that will seize the threads and they will NEVER come out. Guess how I know... ::)
If you use anti seize, you will insulate the two metals. We already have steel fasteners in our aluminum parts.
