Author Topic: Outer clutch install help please  (Read 2018 times)
Offline Magpie
« on: May 18, 2007, 05:08:57 PM »
Hi gang!
Any tips for installing the outer clutch basket? I can get it to within about a 1/4 to 1/8'th inch from home. The gear on the rear of the basket hasn't engaged the one on the kick starter yet. I have been tapping at it with the end of a deadblow hammer but it hasn't budged from the last few blows.  Any tips?
Cliff.
Offline 750goes
  • it will live
Re: Outer clutch install help please
« Reply #1 on: May 18, 2007, 05:32:37 PM »
try moving the kickstarter by hand while wriggling the clutch baset left/right???
Offline Magpie
« Reply #2 on: May 18, 2007, 08:22:50 PM »
Thanks 750 but there's no wiggle room. I had to use a puller to get it off. I wonder if I heat up the basket to expand it then try to slip it on/in? Sounds kind of kinky but it is Friday night.
Cliff.
Offline Magpie
« Reply #3 on: May 18, 2007, 08:28:48 PM »
Heating will make it expand and the hole will be smaller.... DOH!! I'll try putting it in the freezer over night, when I get a puller to get it off.  ::)
Cliff.
Offline mcpuffett
« Reply #4 on: May 19, 2007, 01:17:28 PM »
Hi Cliff , i can't remember if they only go one way or not ? might be worth looking at , my f1 was tight going back on , cheers mick.
Offline Magpie
« Reply #5 on: May 20, 2007, 03:07:24 PM »
Hi mc!
Don't know, I have several clutches and all the outers look the same. I'm trying another outer and I can get it about 1/4" away from home, it hasn't mated with the kick start gear and I'm afraid to keep pounding on it. The trans shaft is just held in by the 2 set rings and I don't know how much strain they can take without damaging the cases. It just doesn't seem right to keep beating on it. I must be missing something but the manual says to simply put it on the shaft.
Cliff.
Offline Magpie
« Reply #6 on: May 21, 2007, 08:40:34 PM »
Got it!! A little heat and putting the kick start lever on the shaft to better control the kick start gear meshing with the basket.  Still learning at my age - imagine!
Cliff.
Offline merc2dogs
« Reply #7 on: May 21, 2007, 09:05:56 PM »
 Normally if you stop learning it's because you've been placed in a box  ;D
Ken.
