Author Topic: here we go again  (Read 2192 times)
stanghater
here we go again
« on: June 24, 2005, 04:09:17 PM »
so, i rode my bike to work today, ran great. when i got off, i came out and started it up and basked in the glory of the fact that my bike is running good. it was about 90 degrees out. on the way home i got stuck in traffic. then, my bike would not run hardly. it almost acted like a cylinder wasnt firing. it would get about 45 mph or 5k rpm. i was scared(this happened on the freeway) so i pulled over on an exit and took a look at it. nothing. it wouldnt rev up at all and it was popping and backfiring like crazy on the down rev. Well, i decided to limp it home and once i got going, i seemed to run way better... i dint try to rev it up or anything but it was running better. idling like crap tho....... any thoughts?
Offline cben750f0
Re: here we go again
« Reply #1 on: June 24, 2005, 05:12:26 PM »
any black smoke?.. any smoke at all?... All your carb clamps tight.. not sucking air, when its running, did you pull the spark caps one at a time to see if one cylinder was out?.. do you have a fuel filter that might be bloked?... man this is a  curly one... anyone else?
« Reply #2 on: June 24, 2005, 05:47:06 PM »
What model bike?
stanghater
« Reply #3 on: June 24, 2005, 06:55:09 PM »
no, yes, no,yes, no
81 cb650 custom. i just rode it and it ran great.... did it overheat?
Offline oldbiker
  • I HATE RAIN
« Reply #4 on: June 25, 2005, 12:45:51 AM »
Just a thought, is the vent in the tank cap clear.
Offline Robert
  • Sorry for my English
« Reply #5 on: June 25, 2005, 06:11:47 AM »
Classic symptom. Either ign. coil or pulser is f....d
stanghater
« Reply #6 on: June 25, 2005, 08:50:40 AM »
where are these parts located and is there a link to where i can buy new ones?
Offline Robert
« Reply #7 on: June 26, 2005, 07:27:24 AM »
Pulsers are a behind the round cover that says HONDA (right hand side, below the cylinder)
Ign. Coil: Follow the ignition cable   ;)  (below fuel tank)
Parts: see FAQ here or http://thehondacbforum.com/  ->  shop
