Author Topic: Will a 1975 airbox work on a 78???  (Read 1846 times)
Rain City Rider
« on: June 25, 2005, 08:58:19 AM »
I have a 78 cb750 and was wondering if a 75 airbox would work.
eldar
Re: Will a 1975 airbox work on a 78???
« Reply #1 on: June 25, 2005, 11:10:44 AM »
Well I can say for sure, but I dont thing there were any major changes in airbox design between those years. They look the same and I think use the same air filter.
Buffo
« Reply #2 on: June 25, 2005, 10:03:47 PM »
try to bolt it on. Make sure all of your hoses that are suppose to run to the air box do.
Don
Offline scondon
  • Mmmm......tasty bugs
« Reply #3 on: June 25, 2005, 11:25:35 PM »
The airbox will fit but the rubber "trumpets" that fit to the carbs are a different size, at least on the F models. Not sure about K models
Offline gkw120649
« Reply #4 on: June 27, 2005, 08:42:43 AM »
The 1977 & 1978 carbs have a bigger diameter where the airbox goes on the carbs.  I put 75 carbs on my 77 and had to get an older airbox.  I have the complete setup from the conversion.  I was going to put the parts on ebay.  Let me know if you want some of the 77 parts.
1977 CB-750 K
1978 CB-750 K
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
« Reply #5 on: June 28, 2005, 04:46:42 AM »
you will need to pick up the rubber  stacks that go from carb to box where as they are bigger on the 77 78 now  my younger brother went the other way and the bigger stack slide on easier and do tighten up enough good luck  Craig
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
