Author Topic: leaky intake manifold  (Read 1878 times)
Offline cadler
« on: May 22, 2007, 07:38:45 AM »
Anybody ever have a leaky intake manifold. Does not matter what bike, but that is where I am going next to debug this cb450.
if anyone has had one, what were your symptoms?
Thanks
Offline edbikerii
    • Gallery
Re: leaky intake manifold
« Reply #1 on: May 22, 2007, 09:44:12 AM »
Bike runs like @$$.
Spray intake, including the surface that mates with the head, with WD40.  If the idle improves (or changes at all, really), then you have a leak somewhere.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline cadler
« Reply #2 on: May 22, 2007, 12:22:41 PM »
this is what i get.  a nice idle at 1000rpms,then give it gas and idle sticks at 3000rpms.
when i spray carb cleaner around manifold it will knock it back down to 1k.
Bar50
« Reply #3 on: May 29, 2007, 09:37:26 AM »
Look for cracks in the manifold/boots.  If you can narrow it down to one or two with the Wd-40 it helps, but, if you got to replace them, I would put them all on.  Some times you can rev up the bike and chock out each carb buy hand(over the carb opening with the air filters off) if it has trash in it, sometimes it will suck the gunk through...not much help with an intak leak though.
Offline cadler
« Reply #4 on: May 30, 2007, 07:32:09 AM »
I think I found the problem, there are no gaskets behind the manifolds. I guess i did not expect something like that because the bike had only 14000 miles. Why would someone remove them?
Craig
Offline edbikerii
    • Gallery
« Reply #5 on: May 30, 2007, 07:36:26 AM »
Maybe PO had no business turning a wrench.  I've seen dumber than that, for sure.  Consider yourself lucky the PO didn't try to seal that surface with epoxy or roofing tar or something stupid like that.  Are they supposed to be o-rings like the CB550, or just flat gaskets?
Craig
SOHC4 #289
1977 CB550K - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline cadler
« Reply #6 on: May 30, 2007, 10:56:14 AM »
I will let you know, I just ordered them from David silvers. I think they are flat gaskets.
Do you know if I should put on  non hardening gasket sealer or just use the gaskets?
Offline edbikerii
    • Gallery
« Reply #7 on: May 30, 2007, 12:01:13 PM »
On my 550 those were o-rings and I used Hylomar HPF(?) non-hardening sealer.
Do you know if I should put onĀ  non hardening gasket sealer or just use the gaskets?
SOHC4 #289
1977 CB550K - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline midnightrider
  • Out of the SOHC4 world for a while...
« Reply #8 on: March 11, 2011, 02:15:38 PM »
Did this work out well for you?  Did you check it for leaking after?
1972 CB350 Four - "The Green Hornet"
http://forums.sohc4.net/index.php?topic=84975.0
I love being alive and I will be the best man I possibly can; I will take love wherever I find it and offer it to everyone who will take it... seek knowledge from those wiser and teach those who wish to learn from me.
-- Duane Allman's epitaph
Offline edbikerii
    • Gallery
« Reply #9 on: March 13, 2011, 04:55:51 PM »
Yes.
SOHC4 #289
1977 CB550K - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline MoMo
  • Ride like you're invisible
« Reply #10 on: March 13, 2011, 05:22:47 PM »
Flat gaskets on the CB450 dohc and you should not need to use any sealer-I never have on any of the ones I owned...Larry
