Poll
How often do your carb sync?
What's a carb sink?
1 (1.6%)
Whenever I've opened 'em up
18 (29%)
With my Annual/Semi-Annual Tuneup
23 (37.1%)
Whenever I wash the bike-  I love to Carb sync
1 (1.6%)
I've Not/Ever Done One Yet
19 (30.6%)
Total Members Voted: 51
Author Topic: How often do your carb sync?  (Read 8719 times)
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: How often do your carb sync?
« Reply #25 on: May 23, 2007, 03:57:18 PM »
He said to deliberately misadjust the carbs so that only one was delivering power and then adjust it's idle screw.....repeat for the other three. Having done that...then match the vacuums for all four. Sorta like optimizing the adjustment effect...sounds reasonable.
I don't tend to associate the idle mix adjustment with synching the carbs.  For me, those procedures are completely separate.  Unless you're talking about the idle speed stop screw, but then there's only one which controlls all four carbs.
Not on the K0 carbs :/
No.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #26 on: May 23, 2007, 04:21:53 PM »
Gee, no carb sync lovers so far, what's with that? ::) ;D
Offline Gordon
  • 750K1, 550K2
« Reply #27 on: May 23, 2007, 05:53:43 PM »
Ah, yes.  Now it makes sense! ;D
Offline LoopsAndLogic
  • Dang IT!!!
« Reply #28 on: May 23, 2007, 06:30:49 PM »
Hoping someone could clear things up for me that the OEM shop manual didn't (TT) ;D
Is it, cam chain, valves, points, timing, carb sync with a fresh air filter?
About the last one, is it carb sync after adjusting the air pilot screws evenly, or after?
And lastly, could unbalanced carbs cause a knocking noise from the engine while idling at 1100-1200 rpm??
Cause if I give it throttle and maintain at 1800 rpm and up, it's perfectly smooth and quiet....... except the worn cam chian ;D
It's a 75' CB400F with 24k miles.
Thanks
LL
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
« Reply #29 on: May 23, 2007, 07:18:48 PM »
That's your basic tune up!
Carb sync before pilot screw fine tune.  But, make sure the pilot screws are same number of turns before carb sync.
Well, yes, I guess.  Hard to hear an internet knocking sound, though.  You could be describing transmission gear clack caused by uneven firing impulses between the 4 cylinders changing the crank rotational speed.  There not much of a flywheel on these bikes to keep crank speed even.  Does the noise change with clutch engagement status?
  • Dang IT!!!
« Reply #30 on: May 23, 2007, 07:37:25 PM »
Negative.......With the clutch pulled in, there is no change in the sound.
Reason why I ask about the tune-up, is because I tuned my 76' CB400F last year, and before the maintenance, it had the same noise.
So after my tune-up, I said to my self, " Wait a minute, what the heck, where's that sound?????"
 But as soon as fall arrived, with the temps in the lower 50's, the noise came back!!! Mind you, that was some 4 months later.
Are.... I'm sorry, could the cb400f's be that touchy?? And I made sure the lock nuts didn't move by putting some llaquer paint lines on each.
And lastly, has anybody ever told you that you are 1 big ??? set too this forum??
Your help is very appreciated
LL
My rides:
Past Rides:
bobsmith
« Reply #31 on: June 03, 2007, 08:31:00 AM »
I was hoping to see a bunch of replies saying it isn't necessary, all bikes run fine without synced carbs..sigh
rt
« Reply #32 on: June 03, 2007, 11:16:22 AM »
I never synched carbs on my my 550K. I did a basic manual setup, checked points and sparkplugs plus the ususal stuff and do my regular oil changes but never bothered about carb-synching. For the last four years she always started and never let me down....
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« Reply #33 on: June 03, 2007, 11:39:37 AM »
The inline fours idle and run a lot smoother if the carbs are synced. I have never tried just setting the carbs manually, but the adjustments are so touchy using the guages I don't see how setting them by mechanical measurements is possible. Maybe I should try it once.  ::)
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline mrbreeze
  • Not your average
« Reply #34 on: June 03, 2007, 08:51:45 PM »
If you don't synch your carbs.....you're missing out. If you don't use a Morgan carbtune....you're working too hard!!!!! Just my opinion.
MEMBER # 257
Offline Master Ted
« Reply #35 on: June 04, 2007, 09:27:40 PM »
Morgan Carbtune arrived today in record time... those guys are fast!
I got the case with the tool and am glad I did - very well made, well organized and designed to protect. Highly recommend if you are making a buy! :)
CB750/K2
Offline techy5025
« Reply #36 on: June 05, 2007, 02:02:14 PM »
The only problem with the Morgan Carbtune is that it works so well all your "friends" will want to borrow it!  ;D
Jim
2003 CBR600F4I
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #37 on: June 05, 2007, 03:43:05 PM »
Jim
I won't tell them that I have one, when it gets here the is.  6 days and counting.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
kaysystems
« Reply #38 on: June 05, 2007, 05:16:14 PM »
I agree.. especially on a K0. The Morgan is so much more acurate than gauges.
David
Offline clarkjh
  • Expert? If only.
« Reply #39 on: June 06, 2007, 11:06:02 AM »
Got my CarbtunePro today in the mail ;D ;D, so now I can sync my carbs.  Canada Customs hit me with GST and Canada Post hit me with a $5 COD fee :-[, but now its mine, ALL MINE, MINE I SAY.
Sorry got carried away there for a minute.
James
SOHC/4 #3328
upperlake04
« Reply #40 on: June 06, 2007, 11:18:56 AM »
 ;D So you got the Carbtune James old buddy, old pal.. ;D ;D
Offline clarkjh
  • Expert? If only.
« Reply #41 on: June 06, 2007, 11:23:23 AM »
You provide the beer and the cost of a baby sitter and I'm sure I can make it.  It would only be a 3, 4 day trip up and back ;D
James
SOHC/4 #3328
upperlake04
« Reply #42 on: June 06, 2007, 12:33:09 PM »
 ;D Great! pop over when you have time - its a only a little over 3000 km one way  ;)  The Carbtune definitely seems to be the tool of choice with members here.  http://www.carbtune.com/index.html
Offline clarkjh
  • Expert? If only.
« Reply #43 on: June 06, 2007, 04:12:36 PM »
Thats the one I got, man my bench sinc was way out.  Not to bad now after about 1/2hours work.  Now I just have to wait for the boss to get home so I can take the bike for a spin and see if there is a difference.  Also when I was younger I use to run 3000 to 3800 Miles a week.  Well the 3800 was in 4 days, burned me out.
James
SOHC/4 #3328
