Author Topic: Tales of Dumb-assery! with Skonnie Boy  (Read 2810 times)
Offline Skonnie Boy
    • What I do for a "living":
« on: May 22, 2007, 11:14:31 PM »
Post after post here involves tales of smart and skillful tricks, true expertise and amazing project rehabs.  That's all fine and well, but what about sharing stories of ineptitude and retardation?  Wouldn't that make you feel better about yourself, hearing about people dumber than you making decisions dumber than ones you've made?  Well, I'm here to help.  No need to thank me, no worries.
My '73 750 died on the way home from work today.
OK, I lie.  I stopped at the courthouse after work to pay a ticket, then had a beer at an adjacent bar to recover from the shock of being divested of $120.  Then I headed home.  Fine.
The bike was accelerating erratically, and seemed underpowered.  Idle speed dropped precipitously, until at last the bike died in traffic.
So, in a parking lot of a burger joint, I found myself:
-2.5 miles away from home.
-About 150 ft. lower in altitude than where home is.
-Out of AAA tows, due to my POS Volvo having used them all up some months previous.
I wasn't surprised by the bike dying, however.  I recently replaced the coils with some off a '75, and half-assedly cleaned the tank, in addition to replacing the petcock.  There's also an oil leak coming from the tach cable fitting on the header.  I'm aware of the beautiful and awesome fragility of the machine I'm relying on to get me to work.  That's why I love it, that's why I bought one, that's why I will push it home without complaint or further delay.
An hour and a half later, I finally reach home.  No fewer than 5 people have offered to help me as I push my bike home, including 2 friends who happened to be passing by.  I decline all offers.  Its my bike, I will get it home somehow, I explain.  I am covered with sweat, and for some reason I am wearing leather-soled cowboy boots.  This makes things even more unfun.  Full Gear vs. Fool's Gear, the voiceover in my brain repeats.  Austin, TX is a damn friendly place, though.  Five people offered help.  Hard to beat that.
I'm home, and I begin the diagnosis.  Off comes the gas tank, off comes the petcock.  I'm convinced its a fuel line problem.  Somewhere between the tank and firing chamber lies the problem.  I start to drain the tank, and inspect all the lines.  Nothing seems amiss.  I bury myself in the Clymer manual for half an hour.  The tank drains enough to remove the bottom of the petcock without great mess, and I inspect it.  Weird, there's not as much rust as I thought.  But there's some, so I remove it and clean the petcock filter as well.  I spend another half hour reading the manual just to hunt for other clues and possible causes.  I'm flummoxed.  Its probably a carb issue, way too complex for me right now.  Maybe some crap got drawn into the engine, and I'm screwed.  Maybe my bike will sit for another 2 months.  Again.  Maybe I'm f#¢ked.  God.  Damn.  It.
So I check on the gas tank.  I remove the cannister I drained the bike tank into.  Wow, that's weird.  There's virtually no gas in the cannister.  Almost as if no gas had drained from the gas tank.  Huh.  How 'bout that.  I check the gas tank with a flashight and see the brass pipe rising from the petcock.  Its above the gas in the tank.  Huh.
I take my car to a Texaco and fill up the cannister.  I replace the gas tank, mount the petcock and fill it up.  I hit start.  It runs.  Just like it did before.  Before I ran out of gas.  Oh wait, I get it.
That's right.  I ran out of f#¢king gas.
That's why I pushed my 520 lb. bike 2.5 miles home.  And that's why I passed 2 filling stations, 3 mechanics and 5 offers of help on the way home.  That's why I have 3 blisters on my foot.  That's also how I know the odometer reads according to wheel travel.
And its also why I'm 6 beers into a twelver typing this.  Good night and god bless.
See, don't you feel better?  I know I do.
-A
Yee and/or Haw.
Offline Gordon
  • 750K1, 550K2
Re: Tales of Dumb-assery! with Skonnie Boy
« Reply #1 on: May 22, 2007, 11:32:48 PM »
Yes I do, thanks! ;D
I just went through a similar situation with a friend and his bike a couple of days ago.  He rode it to a party out in Golden and couldn't get it started when it was time to leave.  He tried starting it until the battery couldn't crank the starter anymore, and then unsuccessfully tried push-starting it several times before leaving the bike in the front yard and finally getting a ride home from a friend.
I saw him at work the next day and he told me of his troubles.  I was working an early shift so I told him to give me the key and I'd drive out there to see what I could do after I got off.  I went home, convinced my wife to drive out there with me, grabbed a few tools I might need and the jumper cables, and we were off.
Once there I turned the bike on, closed the choke, pulled in the clutch and noticed the kill switch was in the off position.  Flipped it to "On", pushed the starter button and it fired right up.
That's right, he had the kill switch off the whole time.  He felt like a dumbass, but I told him every single motorcycle rider has done the exact same thing at some point in time! ;D ;D
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: May 22, 2007, 11:35:33 PM »
By the way, which bar did you stop at after paying the ticket?  Austin is my hometown and I like to reminisce occasionally... :'(
Offline 750goes
  • it will live
« Reply #3 on: May 22, 2007, 11:45:18 PM »
 :D :D :D :D :D
happens to all of us at some time
it must be a sohc thing
 :D :D :D :D
Offline Skonnie Boy
« Reply #4 on: May 22, 2007, 11:50:37 PM »
Stopped at a newer bar called Sidebar on 7th and Red River.  Right up the street from the courthouse.  Much better than 6th street.  But I hear stories about 6th st. back in tha day...
Its so funny, Austin Bike culture.  All the Harleys and sporters park on 6th, while the old Beemers, Triumphs and UJMs are on Red River.  I've even spotted a Royal Enfield in front of the Red Eye Fly.
If you're no longer in Austin, a giant howdy to you.   You'd appreciate my trek up S. Lamar & Barton Springs to Hether st.
Best and all that.
Yee and/or Haw.
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: May 22, 2007, 11:59:53 PM »
Best and all that.
Thanks for that!
If you're ever in the mood for some great jazz, stop by the Elephant Room at Congress and 3rd st. and have a black and tan for me. ;D
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #6 on: May 23, 2007, 03:15:08 PM »
F I N E - C
Fuel: gas turned ON. Enough gas in the tank to at least go to the nearest gas station? Petcock in 'on' position, unless you are actually on reserve.
Ignition: turned ON
Neutral: transmission in neutral
Emergency Kill Switch: ON. It's for emergencies. Do not use it to switch your 'bike off.
Choke/Clutch: when engine is cold/if the the'bike has a clutch cut-out
Follow this mantra every time you walk up to the 'bike and you're good to go. If the 'bike stops mysteriously, follow the mantra first. I've lost count of the number of times I've seen a student flailing away on the electric starter, cursing that the 'bike (which was running fine a minute ago) will not start, when they had bumped the kill switch to the off position.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline Badger 5
    • Gallery
« Reply #7 on: May 23, 2007, 03:37:52 PM »
I'll have to keep ol' FINEC in mind.  Took the 550 out yesterday and ran out of gas twice.   For some reason I just couldn't remember to turn the damn petcock on.
76 CB550K
75 CB200T
68 CL160 (AHRMA R78)
07 Triumph Bonneville Black
75 XS650
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #8 on: May 23, 2007, 03:42:35 PM »
nickjtc,
Why? I use it for this all the time to make it an ingrained reflex should I ever need it. Is there some other dastardly reason not to do this other than maybe forgetting to switch it back for your next start?
Offline nickjtc
« Reply #9 on: May 23, 2007, 04:17:30 PM »
nickjtc,
Some of us are a little forgetful. The problem with using the kill switch is that it only stops the engine. It does not turn everything else off. So there is a risk that the rider might be distracted (or just forgetful) and walk away from the 'bike with the lights left on, only to come back and find a flat battery.
1977 Suzuki GS750
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #10 on: May 23, 2007, 04:19:52 PM »
I guess I can see that potential, though my next move is always to shut-off the ignition at the key.
Offline Skonnie Boy
« Reply #11 on: May 23, 2007, 04:31:10 PM »
Same here.
In my defense, my bike is going through lots of gas as its running a bit rich.  I got 60 miles out of 2.5 gallons of gas, though much of it was in slow traffic.  Combine that with being unable to see the level inside the tank, and there you go.  I DID just put in a new petcock, so I should have known from the length of the piping that even though there was significant gas sloshing around, it wasn't enough.
Strange thing is, now it runs very choppy.  Not sure what to chalk that up to.  Might be time to adjust the timing, tho it seems to have come on rather suddenly.  Could it have something to do with higher octane gas I put in?  Humid weather?  Hm.
Yee and/or Haw.
Offline merc2dogs
« Reply #12 on: May 23, 2007, 07:16:17 PM »
nickjtc,
 I've always wondered that myself.
 Hear it everywhere, I ALWAYS shut it of with the kill. My bike key and other keys are on the same ring so I don't forget it.
 Thought it was some safety deal, as most people I've heard it from are instructors or attending/attended riding school.
    it's entire purpose is to shut down the ignition, the only difference is that the other circuits are still useable when it's off, much like  the 'acc' position in autos
 The only key problem I've had is when my keys fell out of the ignition somewhere between Dorr and Newaygo, now I keep a cord tied on the frame and clip my keys to that just in case.
ken.
Offline Stu400
« Reply #13 on: May 28, 2007, 05:05:39 PM »
Idid that the day I bought the bike, In the first petrol station I came across, after filling up, I couldnt restart the bike. I refused all offers of help thinking the bike wouldnt start whilst warm. I HAD ACCIDENTALLY NUDGED THE KILL SWITCH
eldar
« Reply #14 on: May 28, 2007, 05:40:56 PM »
gee I do the kill switch thing all the time. But only for a second and I realize what I did right away! :D
Offline nickjtc
« Reply #15 on: June 02, 2007, 12:27:24 AM »
The whole kill switch thing is a non-issue for me now, since when I changed the switch gear on Sophie to the '68 stuff there was no kill switch.
1977 Suzuki GS750
