Well.....ya know, sometimes ya can't see the forrest thru the trees!
This is a bike my son just bought. Have plated it yet, haven't really ridden it at all. Was running real rough, missing, backfiring when we got it. Cleaned all the carbs, jets, etc. Starts right up but still had this poor trhtottle response. So I was checking the accelerator pump. Following general concensus, punched another hole in the diaphragm. No real change. SO as I was looking at the thing to see if there was any adjustmetn on the pump arm, I noticed it had a fair amount of tension on it with the throttle closed. Like I said, I have never personally ridden this bike, have only fired it in the garage after cleaning things up. Well, I happened to notice that there was no free play n the throttle, absolutely none! So I decided to take care of that and adjusted the cable to give about 10deg free play. Then checked the pump arm and now there was no tension on it at closed throttle!!! Had a few thou clearance. So I fired it up and whoa!!! SMooth rapid revs cracking the throttle open and it even is idleing better and smoother.
The tight throttle cable had so much tension on the pump arm form the get go that cracking the throttle basically got no further response from teh pump! Instead of tearing the carbs apart again and taking the pump apart, all I had to have done was adjust the throttle play! Oh well, at least now I know the pump is good and that it also has two holes n the diaphragm.
