Author Topic: What is the length of 71 cb750 k1 side stand?  (Read 1242 times)
kgreb
« on: May 23, 2007, 06:26:38 AM »
I really need to know!
TIA
kgreb
Offline Kevin D
  • SE Michigan
Re: What is the length of 71 cb750 k1 side stand?
« Reply #1 on: May 23, 2007, 08:04:36 PM »
Hey kgreb, it's about 7 from the pivot bolt to the heel.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
kgreb
« Reply #2 on: May 24, 2007, 05:59:45 AM »
Thanks a bunch, KevinD!
Does your stand hit the rubber stopper on the exhaust in the center or the edge. Mine just misses it. Which stopper (rectangle or circle) is used for the side stand?
I bought a used stand and it looks appropriate but it misses the stopper and i am wondering if I should keep looking for another stand.
kgreb
Offline Kevin D
  • SE Michigan
« Reply #3 on: May 24, 2007, 03:11:47 PM »
xtra busy right now but will follow with better info (photo?) later -  my 341 pipes are not OE but they have the same footprint as the 300's - the bumper is placed a little too short for the length of the stand and doesn't nearly hit on center - will post photo later after I clean it up - theres a rectangle bumper for the sidestand - check the partsfiches to see if placement is right.
http://members.tripod.com/cb750K2/parts-manuals/index.html
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
kgreb
« Reply #4 on: May 25, 2007, 11:01:54 AM »
I appreciate your help KevinD!
kgreb
Offline Kevin D
  • SE Michigan
« Reply #5 on: May 28, 2007, 04:56:04 AM »
Maybe these photos will be helpful:
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
kgreb
« Reply #6 on: May 29, 2007, 06:10:59 AM »
Again. Thanks KevinD. This helps. I think my stand must be slightly bent. I am going to measure it after I take it off and look at it again.
kgreb
