Author Topic: Polishing up my carbs!  (Read 1848 times)
Offline Short Round
« on: May 24, 2007, 08:49:10 AM »
So since I am having to wait until my friend gets his shop finished to begin on my 550 restoration/ Cafe project and it has been eating at me since I found out that the rings were bad, I figured I would occupy myself with some polishing.  Began with an hour soak in Simple Green then scrubbed then with some scotchbrite.  Moved everything over to my Dremel and went to town with a stainless wire wheel to get in all the nook and cracks.  I then hit them up with 300 then 400 grit sand paper followed by some steel wool.  Finally I ended the day at my polishing wheel and polished to a mirror shine.
1974 CB550
Offline Short Round
Re: Polishing up my carbs!
« Reply #1 on: May 24, 2007, 08:57:08 AM »
more pics
1974 CB550
Offline DrMark
« Reply #2 on: May 24, 2007, 09:29:34 AM »
Very nice...might have to give that a try on my set....
1978 CB550K
1983 CB650SC Nighthawk
Offline greenjeans
  • 1972 CB750K2
« Reply #3 on: May 24, 2007, 09:33:44 AM »
Looks great... makes all the difference in the world.
You can also polish those brass bits as well....drain plugs & nuts/caps on the sliders for some
extra bling....
Offline Short Round
« Reply #4 on: May 24, 2007, 09:43:41 AM »
does anyone know where I can get ahold of some new/newer drain plugs.  Mine are all messed up........................CHris
1974 CB550
Offline snyquist53
  • party time
« Reply #5 on: May 24, 2007, 11:10:08 AM »
looks good 8)
74 cb750, 71 cb450, 77 cb550, 74 cl350, 74 sl200, 00 vt110, 77 sporty ironhead
DOG PILE
RSV12K
« Reply #6 on: May 24, 2007, 11:33:13 AM »
I already did that. Now, start polishing the tops of all your bolts.
Offline Raul CB750K1
« Reply #7 on: May 24, 2007, 11:49:56 AM »
Did you use the wheels to polish your toe nails too?  ;D ;D
Nice work. I really never cared much about polishing the carbs. They are not much visible after all; you can't clean them to keep the polish. A nice bright on the fenders, engine cases or fork bottoms catch more views.
« Last Edit: May 24, 2007, 11:54:18 AM by Raul CB750K1 »
Offline Short Round
« Reply #8 on: May 24, 2007, 11:58:31 AM »
Yeah everything else is next, this just gave me something to do while I am waiting and what not, so i thought I would post the results.  The bowls actually came out more shiny than I wanted so I resanded and went back over them with steel wool for the satin look,  I'll post that when I get them finished.
1974 CB550
Offline EdB
  • i didnt break down, i like to rebuild it on the side of the road
« Reply #9 on: May 24, 2007, 01:11:55 PM »
looks sweet. but wouldn't want to do on my bike. wouldn't match the oil leaks, break fluid leaks, and flat black everything  ;D
But thence came the Great Schism, when the two like tribes diverged, and the Bobbers did take the Road to Cruiserdom and the Cafe Racers did ride to Sportbikedom and they did pollute the lands along their paths with their abominable spawn of Choppers, Stuntaz and like manner of unholy douchebaggery
