Author Topic: '81cb650c exhaust(4-4) on a '79 CB650.  (Read 2677 times)
Offline Soos
« on: May 24, 2007, 10:28:54 PM »
I just fitted a 4-4 onto my '79650 today, gives a sloghtly deeper growl than the stock 4-2's did, not any louder(possibly a little quieter?).
My problem is I no longer can use the stock sidestand now.
I had to chop off the spring mount for the sidestand(on the frame).
The exaust HUGS the frame on the instde(for cyl2), on the left side frame rail.
I intend on drilling and tapping the sidestand mount and machining a theraded post for a new spring to hang off of.
I am going to mount the new post so there is no interference with the new exhaust.(hopefuly!)
But I need to fing a sidestand with the spring mount on the side facing away from the motor.
Anyone know of a bike that uses a kickstand that has the springmount on the outside?(I'll post pics later)
Besides the '81cb650c?(wife almost hit me for swapping exhausts, so taking her sidestand is outta the question)
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: '81cb650c exhaust(4-4) on a '79 CB650.
« Reply #1 on: May 25, 2007, 06:13:51 AM »
Will a generic bolt-on sidestand work?
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline c_kyle
« Reply #2 on: May 25, 2007, 06:23:39 AM »
I would like to see pics of this.
Izanami, my 1979 CB650Z:  Clicky
Offline Soos
« Reply #3 on: May 25, 2007, 11:47:32 AM »
here you go.
I like the look of the 4-4 a better than the stock 4-2 that it came with.
I had thought of buying a new 4-1, until i got the '81cb650c.
From what i have read on exhausts, the 4-1 gives good top end, and the 4-4 gives best all around performance.
Since this is my daily driver to and from work, i think the 4-4 will actually suit the purpose of this bike a bit better.
The extra wiight that comes from this exhaust is negligible IMO, since i am going to add hard bags, and weight is not a serious consideration on this bike.
The first 2 pics are of a side and end view of my '79 with the 4-4, the second to last picture is of the '79 sidestand mount, the last picture is of the '81 sidestand mount.
« Last Edit: May 25, 2007, 11:57:11 AM by Soos »
-=≡ Soos ≡=-
Offline Soos
« Reply #4 on: May 25, 2007, 11:49:24 AM »
ok, thought i had the pic with the 4-2... here goes.
-=≡ Soos ≡=-
Offline c_kyle
« Reply #5 on: May 25, 2007, 07:12:56 PM »
That exhaust looks good, especially on our bikes.
pyro139
« Reply #6 on: May 25, 2007, 07:20:32 PM »
lol i was going say 81 650 ;D
well if doesnt fit right can take exhaust off and mail to me ill put good use to it on my 81 650c ;D
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #7 on: May 25, 2007, 10:48:27 PM »
Looks like you got the '81 front end there.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline Soos
« Reply #8 on: May 26, 2007, 12:54:30 AM »
kslrr, the front end is off a '79 cb750 DOHC.
Well... the lower legs, brakecalipers, brake rotors, and fender are.
My front rim is off the '79650, with the disks from the 750 mounted on it.
The fork tubes are origional to the '79650 as well as the tripple trees/headlight bucket.
The most noticible way to spot the front end differences is the fender, '79 750 fender is plastic, the '81 cb650c has is chromed metal fender.
I have done MANY mods to this bike, the front end and recently the exhaust being the most noticible.
What i really like as far as mods I've done so far are the pod filters.
they opened up the motor quite a bit. Along with the carb modifications, they keep me smilin' all day.
Almost didn't go to work today...
l8r
P.S. i'm adding some pics of the front ends of the 2 650's i have to show the differences.
The front of the '81650 kinds duckbills up a bit, the 750DOHC fender hugs the tire.
« Last Edit: May 26, 2007, 01:09:34 AM by Soos »
-=≡ Soos ≡=-
Offline Soos
« Reply #9 on: May 26, 2007, 01:13:22 AM »
Just noticed, the 750DOHC legs keep the axle of the wheel centered to the legs, the '81cb650 legs have them ofset from C/L of the legs.
l8r
-=≡ Soos ≡=-
Offline cb650
« Reply #10 on: May 26, 2007, 04:02:17 AM »
The dual disk 650's had wider triple clamps for extra clearance on the extra caliper.
                          Terry
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #11 on: May 26, 2007, 10:34:42 AM »
            I really like the way that 750 fender hugs the wheel. Sure gives it a clean look in my opinion. ;)
                                                               Later on, Bill :) ;)
Member # 1969
