Poll
What should I do with this bike?
Restore it?
9 (20.9%)
Customize it?
21 (48.8%)
Just get it going and beat the ever living snot out of it?
10 (23.3%)
Part it out on evilbay?
3 (7%)
Total Members Voted: 34
Author Topic: Project "Hard Luck - The Red Racer" - updated 07/30/2010 w/new project!!!  (Read 111902 times)
Offline KB02
Re: K8 Project "Parts Bike" - CRAP!!! - updated 5/31/2010
« Reply #425 on: May 31, 2010, 04:09:53 PM »
Catastrophic bearing failure.
Note the missing balls from the exploded bearing...
« Last Edit: June 01, 2010, 04:45:54 AM by KB02 »
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
« Reply #426 on: June 01, 2010, 08:50:28 AM »
wow ... man thats freakin' epic       ..any idea's as to why yet?    with no wheel play at all (witch i find very odd)  i'm leaning towards crappy bearings
Offline KB02
« Reply #427 on: June 01, 2010, 09:45:57 AM »
It appears that there is a spacer that goes between the two bearings that I either forgot to put in, or the wheel never had. Looks like I've got to blame myself on this one... damn it...
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
« Reply #428 on: June 01, 2010, 02:03:47 PM »
when i built my wheels , i almost forgot that spacer .... eek
my rear wheel's spacer wouldn't cooperate so it got left out , havn't had any issues with it yet ... and it's been 3 seasons.
(so don't worry about the back wheel)
Offline KB02
Re: K8 Project "Parts Bike" - problem fixed? - updated 6/4/2010
« Reply #429 on: June 04, 2010, 03:54:16 AM »
Well, $84 later, I should be back on the road. It's actually $39 in parts and $45 in shipping to make sure parts get here by the end of the week - which they came in yesterday. Got the wheel all back together and on the bike last night. I also got a side stand off of a DOHC CB750C which is about 3/4" shorter than the stock SOHC CB750K stand. I'm much happier with that one. It could still stad to lean over just a touch more, but it's FAR better than it was. On Sunday, I am planning on heading out to the Amercade Motorcycle Rally in Lake George, NY for the week on the bike. In Theory, I should be good to go.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline HedNut
  • Underwater Basket Weaving
« Reply #430 on: June 04, 2010, 06:33:42 AM »
Great to hear!! Glad she's back in action!  Excellent news and have fun at the Rally!
« Reply #431 on: June 04, 2010, 07:45:35 AM »
damn that was fast ..
love it when #$%* comes together ... good to hear brother
Offline KB02
Re: K8 Project "Parts Bike" - taking a trip - updated 6/6/2010
« Reply #432 on: June 06, 2010, 05:15:30 AM »
It is Sunday the 6th of June and I am getting ready to head out to the Americade Motorcycle rally in Lake George, NY. And By god I am riding a bike that I build over there.  8) Of course, it's raining like a bugger...  :P That's okay though: It gives me a chance to check out how the bike will do in the rain.
I relaxed the throttle return spring a bit and re-oiled the air filters. I'll double check the tire pressure and top off the gas tank and then I'll be good to go. I'll post some pics when I get back.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline HedNut
« Reply #433 on: June 07, 2010, 02:32:50 AM »
Awesome! Enjoy it man!
traveler
« Reply #434 on: June 07, 2010, 04:32:05 AM »
The spacer takes the torsional load off the bearings.  Not using the spacer will cause the bearing to wear out prematurely.
~Joe
« Reply #435 on: June 07, 2010, 05:31:52 AM »
.....pretty sure he figured that one out  ;)
traveler
« Reply #436 on: June 07, 2010, 09:47:45 AM »
it was for your info too! ;D
Offline KB02
« Reply #437 on: June 13, 2010, 12:06:51 PM »
~Joe
I would say that is a big 10-4.  ;)
AND no sooner than I arrived at my destination, but the valve cover gasket sprung a great huge leak and the bike was grounded once again... DAMN IT!!!!
Doesn't appear to be anything major at the moment other than a bad gasket, but I'll have to pull down the top of the engine to know for sure. While I was there I tightened down the cover bolts just a touch more and the leak slowed, but it didn't stop. Then it got worse. I'm hoping it's not one of the pucks under the cam towers. It's just a major pain in the ass to fix those.
...more to come...
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline KB02
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline KB02
Re: K8 Project "Parts Bike" - updated 07/13/2010 with a few pics
« Reply #439 on: July 13, 2010, 05:19:18 AM »
So, if you hadn't checked out the link above, the leak turned out to be loosening bolts/nuts on the cam holder that allowed oil to not pass up into the cam holder, but out the rubber puck instead: destroying the cam, cam holder, caps and 4 out of 8 rocker arms along with it.
Less that 400 miles on the bike since rebuild:
I got the head cleaned off:
I got a good deal on some used parts that were in good shape and bought a new cam. I went with the WebCam 63a grind this time (Hard welded - better than the billet I killed). I always kind of regretted going as mild as I did with the mild cam. I've got it bored out to 850, head ported and polished - why go with a mild cam?
Anyway, I got the new pucks installed (with just a touch of silicone sealant on them). I pulled and reinstalled the studs for the cam towers (with a bit of thread sealer on them). And I got the cam into place with the notch at 12 o'clock with 1-4 at TDC. Next comes dialing in the cam to be sure that I have it just right.
I'm sure that I can search and find it, but does anyone happen to have the timing specs for the Web Cam 63a handy?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline mrrch
« Reply #440 on: July 13, 2010, 06:49:42 PM »
Go to Dynoman's website and look under cams, I was looking around this afternoon and found cam timing info listed under various cams.
my build
« Reply #441 on: July 14, 2010, 09:48:20 AM »
i officially rename your bike "Hard Luck"  ...... if it's not one thing it's another .. at least now you'll have the cam you wanted
good luck break a leg, my friend  ;) ;)
Offline KB02
« Reply #442 on: July 15, 2010, 04:28:59 AM »
 ;D ;D ;D
I like it.
« Last Edit: July 15, 2010, 05:05:50 AM by KB02 »
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline Aladinsane07
I just got through the entire thread.  Wonderful read.  I really love how this turned out.
And as for the setbacks as of late, I hope they make every ride more enjoyable in the future.   :)
Offline KB02
Thanks. I think it turned out pretty good, too. And I hope these setbacks make every ride better, too.  :)
With any luck I might be able to get back out and work on the cam tonight after work tonight. While I have it torn down, I've got a few little oil leaks I want to address as well. Then I should be ready for another run.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline KB02
Got the cam timed in finally. The next engine I build will have a Megacycle Cam. At least they give timing numbers you can believe. I replaced the gasket on the shifter cover to help stop that leak as well. Now I just need to swap in a new oil filter, put new oil in the bike and run an oil pressure test to make sure that oil will be getting up to the new cam and rockets and then I will be ready to button it all back up.
And, remember this?
He should be born any day now. Due date is tomorrow. Not sure when the bike will be all back together once he shows up.  ::) But, somehow, that's Okay.  ;D
« Last Edit: July 27, 2010, 05:53:55 AM by KB02 »
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline Zaipai
    • My Home page
Gratz ahead of time to you and your SO.. I completely understand. Some things take priority over the bike.. I know hard to believe how ever its true. ;)
Enjoy the calm before the storm!
.: Scott :.
Its my Avatar..
75 CB550F  |
AMEN it that .. good luck my friend ..(you'll need it)
Offline KB02
Got the tappets all adjusted and buttoned up the top end
Then got everything else all buttoned up and plugged in the charger for a little bit while I had lunch
Took it or a ride. Synced the carbs. Took it for another ride. Feels nice to have it back on the road.  ;D AND, so far, anyway, no more oil leaks. I do have an oil line from the tank that seems to be a bit weepy, but I'm planning on replacing those old lines anyway, so I'm too worried about that.
The biggest thing that is bugging me is an inconsistent idle. The engine will race at 3-4K rpm for a little bit then idle down so low that it stalls out. I'm going to have to do some research and look for a solution to that. It's driving my nuts.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
when i first put in my Megacycle cam , it idled very differently at low rpms (still does actually).. and it really made setting the timing kind of a chore as well  ... food for thought
