Author Topic: Unusual Plugs in a Race Motor  (Read 1249 times)
Offline 736cc
« on: May 29, 2007, 09:47:07 AM »
I got this Yoshimura CB750 heavily-modified motor from mid 1970's and its got Champion R-6G w/ tiny electrodes. Anybody know of such a plug and what do race motors on street fuel usually run for plugs?
Offline ken736cc
  • When the cops pull me over, I usually let them off with just a warning.
Re: Unusual Plugs in a Race Motor
« Reply #1 on: May 29, 2007, 10:43:56 AM »
R6G cross references to NGK DR8EIX. DR8EIX is a fine wire electrode iridium tip version of DR8ES
K0 sandcast(in process of restoration), K0 diecast, K0 cafe racer
BMW R69S daily rider, 71SL350, 71 SL100, 63 SS50
Offline 736cc
« Reply #2 on: May 29, 2007, 02:40:50 PM »
Whadya think, should I run this type of plug or go NGKD8ES? Or are those Champs a better plug? Bike will get spanked at every opportunity, of course.
Offline rangelov
  • The Dual Disc Conversion Speedometer Driver
« Reply #3 on: May 29, 2007, 04:32:46 PM »
Champions are fine.  NGKs are fine.  (NDs [Denso] suck). The fine tip lasts longer (noble metal).  A standard tip usually sparks better.  Fine wire tip MAY unshroud spark.
Either way.  Depends how you run, where you run, etc.  Depends how often you pull'em abd replace 'em.  Standards are easy to get and cheaper.  Fine wire should last 50,000 - 100,000 miles.
http://forums.sohc4.net/index.php?topic=76835
CB750K4, Boss maroon metallic, 836cc, RC Engrg 4 into 1, Forks by Frank, air assisted front forks,  JC Whitney 16" rear.
« Reply #4 on: May 29, 2007, 06:53:05 PM »
I have had excellent results with Denso Iridiums in my 3 bikes and cars. I think the design is better than the NGK.
Offline Jonesy
  • Shop Rat
« Reply #5 on: May 29, 2007, 07:36:12 PM »
I too like the ND plugs. Much better than the "Chumpion" plugs you get nowadays...
