Author Topic: Ignition points cover gasket  (Read 1949 times)
kaysystems
« on: May 30, 2007, 05:35:46 PM »
What gasket do you guys use for the points cover on a CB750?
Those cork Honda ones seem to shrink very quickly, then just don't fit.
thanks
David
Offline edbikerii
    • Gallery
Re: Ignition points cover gasket
« Reply #1 on: May 30, 2007, 05:55:31 PM »
Clear RTV.  I made a point (ha ha) of putting some on the bottom of the heads of the screws too.
Then, after going through all that trouble, I noticed that there is a small (drain?) hole at the very bottom of the points area anyway, so the seal is not critical.  At least, that is the case on my 77 CB550.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline ofreen
« Reply #2 on: May 30, 2007, 06:02:21 PM »
I bought a sheet of cork about ten years ago from an auto parts store and made one.  The cork was thicker than the OEM stuff.  It is still in there and looked good when I had the cover off for the 3000 mile service a couple of weeks ago.
Greg
'75 CB750F
« Reply #3 on: May 30, 2007, 06:25:50 PM »
About 20 years ago, I got fed up with the cork gaskets.  Leaked and let water in during rain showers, one time use only.  I went to the hardware store and bought a thin sheet of neoprene.  With a #11 xacto blade, I cut a points cover gasket out of the neoprene.  No leaks and I'm using the same one I made 20 years ago.
Offline medic09
« Reply #4 on: May 30, 2007, 06:28:54 PM »
I bought gasket material at the auto parts store and cut it to fit.  Just tell them what you want to use it for.  I had to buy a whole roll, but it was only about $9.00 for a synthetic/cork material, and it has other uses.
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline edbikerii
    • Gallery
« Reply #5 on: May 30, 2007, 08:02:56 PM »
TT, did you notice the hole at the bottom on your 550s?  I guess water won't run UP into the points area, but it seems like enough riding in the rain might get water up there.  I didn't seal it up, as it seems Soichiro thought it was a good place for drainage or something.
SOHC4 #289
1977 CB550K - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
« Reply #6 on: May 30, 2007, 08:48:17 PM »
Yes, I noticed the drain at the low point.  It stays open with the neoprene gasket.  But, water doesn't come streaming in from the front anymore.
Offline edbikerii
    • Gallery
« Reply #7 on: May 30, 2007, 08:52:38 PM »
OK, thanks.
SOHC4 #289
1977 CB550K - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
kaysystems
« Reply #8 on: May 31, 2007, 03:42:02 AM »
Thanks guys. It's off to the hardware store for me.
David
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #9 on: May 31, 2007, 03:56:11 AM »
It also provides someplace for the oil to drip out for those of us with a leaky points seal. ;)
bobsmith
« Reply #10 on: June 01, 2007, 05:14:06 PM »
OMG, Bob.  but then, I guess the poimt pivots do need a little lube..
