Author Topic: Slow jet for CB550.  (Read 1682 times)
sjschauer
Slow jet for CB550.
« on: June 27, 2005, 10:10:08 AM »
I'm reassembling my Carbs after rebuilding them with Keyster Carb kits. I replaced the Slow Jet, and am uncertain about how it should be set...
Am I correct in threading it fully into it's position? An acquaintance has told me it's one of the screws that's supposed to be tightened, and then backed off a couple of turns. I can't find documentaion of that anywhere.
What's the correct way to reinstall the new Slow Jet?
Thanks for your help in advance.
Stephen, Los Angeles
Re: Slow jet for CB550.
« Reply #1 on: June 27, 2005, 10:12:52 AM »
Which model and year 550?
sjschauer
« Reply #2 on: June 27, 2005, 10:30:44 AM »
It's a '74 550 engine.
Stephen
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #3 on: June 27, 2005, 10:45:05 AM »
The slow jets (inside the bowl, beside the main jets) get screwed in all the way.  You're thinking about the air-screws that you back-off 1-2 turns.
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
sjschauer
« Reply #4 on: June 27, 2005, 11:00:45 AM »
Thanks for the clarification!
Stephen
