Author Topic: Wing is limping on 2  (Read 1898 times)
Offline 78 k550
« on: June 02, 2007, 06:23:37 PM »
Hey All,
Going over to a friends and about half way there it started running on 2 cylinders. I'll be updateing soon. Going to get a battery for the 750 I need to get it on the road.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Re: Wing is limping on 2
« Reply #1 on: June 03, 2007, 03:05:34 AM »
If its early one could be points, could be coil as its basically same as 750 or if you have REALLY bad Karma have you bust a belt?
Offline 78 k550
« Reply #2 on: June 03, 2007, 07:49:06 AM »
No broken belt. It would of bound up.
just got out the test light. White wire nothing no light turn engine over and then bright light. Put test light to black wire and test light is dimm then turn engine over with kick starter and it brightens up then stay's on but dimm's back down abit, but stays on the complete rotation.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline 78 k550
« Reply #3 on: June 03, 2007, 07:50:02 AM »
Dyna S ignition, not even 2 months old I hope its not it.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #4 on: June 03, 2007, 08:15:36 AM »
Fraid it sounds like it might be. Was it wing specific as they run different coils with a ballast resistor
Offline 78 k550
« Reply #5 on: June 03, 2007, 09:24:45 AM »
yes it is the one for the wing. I have a dyna III lying around I'll try that.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline 78 k550
« Reply #6 on: June 05, 2007, 12:14:36 PM »
swapped wires from the unit and the no spark followed to 3 & 4  It look's to be the unit.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #7 on: June 06, 2007, 05:56:20 AM »
sounds a bit like it
