Author Topic: seized up engine  (Read 1607 times)
drey
seized up engine
« on: June 27, 2005, 06:59:49 PM »
wa sup out der? this is my first post and my first moyorcycle.i purchased a1975 honda 750 ohc for 50 bucks of an old lady,its been sittin around in er yard for at least 8 years.but it does have all da pipes on it and carbs and the gas had been drained out.but i cant get it out a gear when i moved it so i pretty much had to carry it with a buddy!i have gotten advice from people to take the plugs out and pour in pb blaster or wd 40 or even diesel and ley er soak for a couple of days,to loosen up the pistons.and they say to drain the oil out and pour in automatic transmission fluid and let it soak.so i might try that unless i hear of any other sugestions or if anybody else has been through this and had success.but this might sound stupid but im new to all this ,but i dunno where to refill the oil?where can this be found?would much apreciate feed-back thanx .......Drey
Mikeshonda750F
Re: seized up engine
« Reply #1 on: June 28, 2005, 03:58:16 PM »
Sit on the bike... behind the side cover on your right side is the oil tank.. this is where you re-fill from.
Ben
« Reply #2 on: June 28, 2005, 04:06:55 PM »
And get a repair manual as quick as you can, you are gonna need it!
Oh yeah, and start to make friends with your honda dealer.............. you will be seeing alot more of him/her...........
drey
« Reply #3 on: June 28, 2005, 04:29:40 PM »
found it thanx.....Drey
