The fuse normally draws about 2/3 of its rating unless you've made changes to the bike; headlight wattage for example.
This will make the fuse warm but not hot. You should be able to hold your thumb on it.
If it is hotter than this than you may have a restriction nearby for current flow. Clip corrosion, clip misalignment, wrong length fuses, and poor wire connections on the back of the fuse block can all cause excessive fuse heating.
I too am having this problem. I popped the main fuse awhile back, up inside the endcap where I couldnt see it. Had me stumped for awhile since I couldnt see it was blown. If a cop had of rode by, he probally would have thought I was stripping the bike of its parts. Had the sidecovers and tank off trying to find out why I didnt have any juice.
![Grin ;D](http://forums.sohc4.net/Smileys/default/grin.gif)
Finally saw the fuse had popped inside the cap and I was on my way again.
Friday morning was on my way to work and I lost power again. Figured the fuse had blown so I cut the ziptye securing the bottom sidecover tab...<<<<insert blame on the PO
...checked the fuse and it was good. Wiggled the contacts and I had power again. So I make it to work after fighting to keep the now "nonsecure" sidecover on. Get home Friday after work,cut the ign switch off, then for the heck of it, back on and no power. I wiggle the contacts again and they are burning hot.
![Shocked :o](http://forums.sohc4.net/Smileys/default/shocked.gif)
Tomorrow will go thru the connections behind the fuseblock, probally to find a cruddy mess. Will clean it up just to get me thru until my 4 fuse ATC style fuse block gets here. Planning on doing the relay upgrade on the headlite as well. Might as well get rid of all the gremlin prone areas at once and be done with it.
Sorry for the rant....just figured I would add my electrical woes into the pot.
