Author Topic: oil change - oil won't drain from the reservoir  (Read 1185 times)
Offline moduleum
  • 1976 CB750 K6
« on: June 08, 2007, 08:07:54 PM »
whiskey
tango
foxtrot?
Do I just have to keep kicking the engine over via kickstart?  I read something about an in-line check valve that may be keeping the oil from getting to the crankcase.  I kicked it over a few times and used the starter too.  However, the dribble rate just increases slightly...no steady stream and the reservoir is still half full? whiskey tango????
Offline scondon
  • Mmmm......tasty bugs
Re: oil change - oil won't drain from the reservoir
« Reply #1 on: June 08, 2007, 08:37:58 PM »
Remove the drain plug from the reservoir?
Offline joeb
« Reply #2 on: June 09, 2007, 06:09:18 AM »
Yep spounds like the drain plug.
Offline ChevelleSSLS6
  • Member #4051
    • my myspace, yay.
« Reply #3 on: June 09, 2007, 10:10:18 AM »
are you sure it's not all sludge? :'(
"What about incomplete idiots?" -TwoTired
"What's a leakdown test?  I filled the cylinder that looks like this with some water and let it sit overnight. The water didn't go down any.  I thought that would tell me about the rings." -Dead Guy of AMCforums
1977 CB550f- sold
2007 Kawi EX650- curre
Offline crazypj
  • I'm brill, me
« Reply #4 on: June 09, 2007, 03:15:58 PM »
whiskey
tango
foxtrot?
 You did pull the right side frame  cover and remove drain bolt?
PJ
bobsmith
« Reply #5 on: June 09, 2007, 03:22:08 PM »
Im not trying to be a smartass, but "HUH?"    I hope it's not sludge (unlikely)     I presume you opened the drainplug on the tank, If it didnt drain, it was empty. if sludge. run a wire into the fitting.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #6 on: June 09, 2007, 04:22:58 PM »
Remove drain plug from oil pan.
Remove oil filter.
Drain oil tank.
That's all it should take.
No.
