Author Topic: Bondo baby, Bondo!  (Read 1202 times)
Offline gregwaits
  • Damn, riding a CB750 sure is fun!
    • waits music
Bondo baby, Bondo!
« on: June 08, 2007, 10:03:42 PM »
Despite all the talk of maybe using a different tank on my cb500 project other than the stock one, I am forging ahead getting it ready to repaint.
Last night a buddy of mine gave me a tutorial on Bondo and off I go. I hope this tank turns out well.
I'll post progess photos as I go along.
1978 CB750K8; 1970 CB450
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: Bondo baby, Bondo!
« Reply #1 on: June 10, 2007, 07:46:39 AM »
Use it sparingly, Grasshopper ;)
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #2 on: June 10, 2007, 02:31:10 PM »
Me and Bondo don't "mix" too well.
I always put it on too thick, spend way too much time sanding it, then it just cracks off.
I gave up doing bodywork along time ago - way to frustrating  ;D
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #3 on: June 11, 2007, 02:53:30 AM »
Same here >:(
I've got to the point where I'd much rather spend the time doing a cash job or two on the side, then using that cash to pay someone to do the job properly :)
It does also help to have a good buddy in the trade who believes, as I do, and as does everyone here seemingly, that there is no such thing as 'beyond salvage' ;D
1978 CB550 K3
1985 H100S
Offline greenjeans
  • 1972 CB750K2
« Reply #4 on: June 11, 2007, 06:18:38 AM »
Man.... that stuff has been around for 40 - 50 yrs or more.  It works.  A bit of advice, get some aircraft brand paint stripper and strip the tank down to bare metal.  Hit it with 80 grit and clean with acetone etc...  Mix the bondo per instructions - it won't come off.  * Make sure you sand it with a sanding block or similar to get it flat...sanding with bare hands or orbital sanders may leave it smooth to the touch, but will often leave a surface that isn't flat.  start with 80, end up with 120 or 220 then you're ready for primer.   One last tip - If you can, when your fininshed with the bondo, let the tank sit for a while....leave it out in the sun etc.  Leave it a week if you have the time.  Make sure it's good and cured before you primer it... I just got finished doing the body work on my 2 projects and I used some Bondo I got at the local WallyWorld for 7 bucks..can't beat that price & a little satisfaction on doing it yourself.
Offline gregwaits
    • waits music
« Reply #5 on: June 11, 2007, 11:53:14 PM »
Thanks for the advice. greenjeans; I have been working with an oribital, and it is real tricky.
Offline droopy
« Reply #6 on: June 12, 2007, 02:20:06 AM »
block sand all stages to get surface flat  at the 120 grit stage apply very thin coat of putty glaze it fills in all the pin holes and scratches that are just a hair to low. makes everything nicer in the end. ;D I always goto 220 grit then primer 2 coats wetsand with 400 grit then dry and tack cloth area (primer again  >:( if i break through the primer and wet sand again) Then paint
« Last Edit: June 12, 2007, 07:49:03 AM by droopy »
2007 lifan 200cc sport ohc thumper
Offline gregwaits
    • waits music
« Reply #7 on: June 12, 2007, 05:32:57 AM »
Droopy..thanks for the comments.
What is tack cloth?
Offline CrisPDuk
« Reply #8 on: June 12, 2007, 06:10:28 AM »
It's like an anti static cloth that draws any fine dust of the piece and also stops it attracting more during spraying
1978 CB550 K3
1985 H100S
Offline matchanu
« Reply #9 on: June 12, 2007, 07:17:25 AM »
Try Duraglass.
It's like Bondo but has fiberglass reinforcement. It's a hell of a lot stronger and more flexible, but a bit harder to smooth out and fine tune.
I use Duraglass first, then a thin layer of Bondo over the top, then spot putty for any pin holes left from air bubbles.
Filler primer is next, you can get it in rattle can now.
There are some very nice and very expensive fillers out there, but I find the less expesive stuff works just fine.
I'm just about done with my bodywork, I'll post pics when I finish it.
Offline oldfordguy
  • A sheepdog.
« Reply #10 on: June 12, 2007, 04:31:54 PM »
I second matchanu's comment on the duraglas.  Also, when using a tack cloth, only lightly drag it across the surface, don't apply pressure to it.  It is impregnated with a wax that will collect any dust on the surface.  If it is used too aggressively, it will leave behind some of the wax which is disasterous to the paint job.
Matt
Offline droopy
« Reply #11 on: June 12, 2007, 06:56:46 PM »
I second matchanu's comment on the duraglas.  Also, when using a tack cloth, only lightly drag it across the surface, don't apply pressure to it.  It is impregnated with a wax that will collect any dust on the surface.  If it is used too aggressively, it will leave behind some of the wax which is disastrous to the paint job.
Matt
I agree hard to remember all this stuff  ;)
