Author Topic: What is this toolset part?  (Read 11167 times)
Offline jensk
« on: June 09, 2007, 12:45:23 AM »
Below is a photo of a toolset I bought for $7 at a "stumpemarked" (open marked for classic bike and car parts) in Gjern, Denmark last weekend.
What i don't know is what is the tool on the far left for?
Anybody got an idea?
I think it is the original toolset for a 70ties Sohc/4 Honda.
It will fit perfectly under my refernished seat when it is finished.
/jens
'77 CB550K Technical rebuild done and riding. Cosmetics must wait till winter
'78 CB550K3 beautifull but engine needs rebuild.
Offline 750goes
  • it will live
Re: What is this toolset part?
« Reply #1 on: June 09, 2007, 12:55:56 AM »
It looks to me like a spoke wrench...
Offline jensk
« Reply #2 on: June 09, 2007, 01:07:27 AM »
It might look like a spokewrench but then it isn't for my CB550. The wrench opening is 8 mm and far to wide for my spokes.
Maybe it wasn't a part of the original toolset or maybe the toolset is not originally for a sohc/4 Honda?
/jens
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #3 on: June 09, 2007, 01:37:10 AM »
I can't tell you what it is, but I can tell you that there isn't one in my 550's toolkit
1978 CB550 K3
1985 H100S
« Reply #4 on: June 09, 2007, 01:50:54 AM »
I have no idea what it is , buti have seen them in toolkits before and yes its for a 70's 750 or 500. Got yourself a bargain there
SOHC steve
« Reply #5 on: June 09, 2007, 02:15:56 AM »
Could it be a tappet adjuster....or maybe just proof that someone at the Honda factory had a great sense of humour ;D
Offline Gordon
  • 750K1, 550K2
« Reply #6 on: June 09, 2007, 02:31:32 AM »
If it's 8mm then I'd say you're probably right.  That's also the size of the brake bleeder valve.
Offline JohnG
  • 1976 CB750F - original owner
« Reply #7 on: June 09, 2007, 04:24:18 AM »
easily worth $40 on Ebay.... complete Honda toolkits do very well. Good bargain!!!
1971 CB450
1979 CB750F
1982 CB900F
1983 CB1123F - Rick Stetson motor
« Reply #8 on: June 09, 2007, 08:17:59 AM »
I use it for removing/replacing the main jets.
Offline Jonesy
  • Shop Rat
« Reply #9 on: June 09, 2007, 08:26:44 AM »
According to the Honda manual:
Looks like the shock adjustment wrench is all that's missing. That funky wrench on the left also serves at the handle for the sparkplug wrench.
« Last Edit: June 09, 2007, 06:26:10 PM by Jonesy »
Offline Bodi
« Reply #10 on: June 09, 2007, 08:38:38 AM »
That funky thing is the extension handle for the axle wrench. The spark plug wrench has a hole to use a screwdriver blade for torque. The other strange one near the middle attaches to the end of the screwdriver blades for torque if the normal handle is insufficient and you need more force to ruin a screw head.
Check that the axle wrench fits your axle nut: there are several different sizes for different modlel bikes and there's no guarantee this set is for yours.
The mystery wrench is... a mystery. It might fit the tappet nuts but I think they are 9mm. You still need something to turn and hold the tappet bolt though...
keepitrunin
« Reply #11 on: June 09, 2007, 03:53:45 PM »
i'll buy the whole kit with pouch off of you and that will solve your delema!
Offline Jonesy
  • Shop Rat
« Reply #12 on: June 09, 2007, 06:28:11 PM »
The axle wrench handle is on the right, meant to slip over the axle wrench itself. I was referring to the wrench in question.
Offline keiths
« Reply #13 on: June 09, 2007, 07:02:15 PM »
I don't know about the tool in question, but I think the Honda tools remained the same for many years and most models. The original tools that came with my 1965 Honda look the same as the ones in the photo above (minus the odd small wrench). And the best part is they are still available from Honda for one or two dollars each. I've seen the whole kit, brand new, for 20 dollars including the pouch, but I think the part number for the pouch has changed.
Offline rhinoracer
« Reply #14 on: June 09, 2007, 08:23:49 PM »
Looks like it fits the front axle. Have to check the bolt size though, I think they're 8mm.
Baja native.
Offline 78 k550
« Reply #15 on: June 09, 2007, 09:34:45 PM »
Only thing I have ever used it for is to loosen or tighten the spark plugs. I use it through tthe holes in the top of the spark plug wrench.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #16 on: June 09, 2007, 09:41:40 PM »
Speaking of...mine runs great!  Thanks to you and those jets.  ;D
How's the new $10,000 engine project coming along?
Offline cben750f0
« Reply #17 on: June 09, 2007, 09:42:27 PM »
i use that one to remove the clip from my joining link on my drive chain.... *shrug*
works   ;D
peace
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #18 on: June 09, 2007, 10:17:45 PM »
That same tool is in my 350f kit and I have never figured it out.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline 750goes
  • it will live
« Reply #19 on: June 09, 2007, 11:12:44 PM »
would it fit the top adjusting nut on the carbs to sync the slides ??
Offline cben750f0
« Reply #20 on: June 10, 2007, 03:19:57 AM »
na they are 14mm aren't they? ???
peace
Offline puppytrax
« Reply #21 on: June 10, 2007, 05:57:03 AM »
That's what I was thinking it was for...the Hondas with endless chains wouldn't have it in the tool kit...just the master-linked chain bikes...   ;D
The Fiche shows it for the 72 CB350F...
13     BAR B, HANDLE
99005-02000    001    $1.39
« Last Edit: June 10, 2007, 06:02:02 AM by puppytrax »
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #22 on: June 10, 2007, 10:34:54 AM »
It's a tuning fork to make sure that the engine is running exactly at the right key ;D ;D
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline Jonesy
  • Shop Rat
« Reply #23 on: June 10, 2007, 12:14:12 PM »
Or the spokes are tightened properly...
Offline rhinoracer
« Reply #24 on: June 10, 2007, 03:08:59 PM »
Might be a multipurpose tool, also used to knock on gas tank to check fuel level.
Baja native.
