Author Topic: POPS but doesn't start  (Read 1305 times)
Offline 736cc
« on: June 09, 2007, 02:14:07 PM »
This CB750 won't start. Its a Pops Yoshimura motor and its barely popping. It literally lets out a healthy pop once in a while, but no signs of starting after about half-hour of cranking w/ choke, w/o choke, half choke, no throttle, half throttle etc. The popping I know is fuel dumping into the header and igniting from the spark, so its getting fuel and spark. Dyna lll ignition and coils off a running bike. Motor is a worked Yoshimura; pistons, valves, cam, porting, polishing, the works. Hasn't started in 25 years. Plugs are irridium tipped Champs that were in the bike; they didn't look bad to begin with, they're a little wet from its non-starting. The Dyna parts can't be put in upside down or anything, right? Theres barely wiggle room to turn the Dyna plate. Wiring checks out ok. Carbs are fresh rebuilt and got fuel in bowls. I'm stumped.
I've put alot of hours getting to this point, totally on a mission. Its been all apart, new tires, rebuilt calipers, rebuilt carbs, new bars, cables, tweaked the bodywork, assorted details. Motor wasn't opened-up, I was assured its healthy.
If and when this thing lights up, its going to be a major happening, so please make suggestions.
Offline scunny
  • don't call me expert
Re: POPS but doesn't start
« Reply #1 on: June 09, 2007, 02:26:30 PM »
have you checked the valve clearances, general tune up bits ?
can you verify the cam timing ?
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #2 on: June 09, 2007, 02:28:00 PM »
Got the plugs firing correctly? Sounds like you might have em at 180 degrees.
No.
Offline 736cc
« Reply #3 on: June 09, 2007, 04:42:27 PM »
ITS ALIVE!
First thing I did was have a beer. Next, removed Dyna plate, flipped the black inductive thing 180 degrees, unplugged and reconnected all ignition wires everywhere, fires up no problem now.
Friggin animal revs FAST when I blip the throttle and absolutely shrieks. Couple more things like carb sync, SS brake lines and a few other details and I'm going to LACONIA this week.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #4 on: June 10, 2007, 08:04:12 AM »
ITS ALIVE!
Rawr, I was right about something!
It sounded familiar from a similar experience I had (don't ask).
Glad it's working!
No.
« Reply #5 on: June 10, 2007, 08:06:42 AM »
Glad its working and see you in Laconia!! Ill be there Saturday :-)
cheers
Andy
