Logo merchandise is available at the SOHC/4 Shop
All lighting is now working but got one question. Is a high flash rate standard for this type or am I in need of a new relay? It's at least double than that of a vehicle. I have also started rust busting the tank, hope it's done by tomorrow.
Are you going to fix that tank, or replace it?
I can't tell for sure from the pictures you have posted but it looks like your fuel lines are running out the wrong direction from the carburetors. If I'm correct there should be two holes on the "plate set" (not sure that is the correct name for it) that the carburetors all connect to. They should be located between carburetors 1 & 2 and 3 & 4. Fuel lines run forward (toward front of bike) through those holes then up towards top of engine and then up to the fuel tank. It didn't make much sense to me to have the fuel lines running on top of the engine but that is the way my 74 CB550 came when I got it. If they work for you the way they are now I would just leave them but the above route does seem to hide them a little better.
