Author Topic: 400-4 CLUTCH  (Read 816 times)
JGR1946
400-4 CLUTCH
« on: June 14, 2007, 06:42:59 AM »
The large gear riveted to the outer clutch housing on my bike has a few degrees of movement. The rivets are tight and there is no play between the centre and the outer case castings of the unit.
Should this play be there? If I try to centre pop the rivets, am I likely to crack the centre and outer clutch castings?
Anyone bolted this assy up?
TIA,  JohnR.  77 400-4 - 85 GL1200A - In Cold Old England.
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: 400-4 CLUTCH
« Reply #1 on: June 14, 2007, 08:13:00 AM »
Sorry, I can't answer your question. But welcome to the forum anyway.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Re: 400-4 CLUTCH
« Reply #2 on: June 14, 2007, 08:28:41 AM »
So long since i looked at one of these I cant remember if it is supposed to have play or not. personally i would not hit any of the rivets but just re-fit it and in the meantime see if i could find another one to check
JGR1946
Re: 400-4 CLUTCH
« Reply #3 on: June 16, 2007, 11:05:28 AM »
Well looking a bit further it appears that the big gear is designed to move a bit on the clutch casting, why would there be the rivets onto an outer steel sheet and not directly onto the gear? BUT my Haynes says somewhere that this should be tight! Also the gear rotation seems to 'land soft' as if there is some shock absorber in there, and does not 'clunk'.
I am not going to bash anything but refit it all as suggested, I only took it appart as it was very heavy and grabbing, ever since I changed the plates and springs a while ago.
Thanks for replies,
JohnR - 400-4 - GL1200A  in Cold Old England.
