Author Topic: best way to lower rear of 1980 cb650  (Read 2470 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« on: June 15, 2007, 11:37:01 AM »
is there a way to lower the stock shocks or do i have to buy short shocks.....or any other ideas..
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: best way to lower rear of 1980 cb650
« Reply #1 on: June 15, 2007, 12:12:24 PM »
Is this for aesthetics or to help you reach the ground more easily? If the latter I would leave the suspension set up as it is and explore getting the seat foam modified with less padding.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline cb650
« Reply #2 on: June 15, 2007, 04:21:29 PM »
lowering blocks.  A search of the site will bring up info.   smaller rear tire.
                        Terry
Offline RatBikeRandy
  • Yes I Can
« Reply #3 on: July 01, 2007, 06:32:39 AM »
Just installed lowering blocks purchased on E-bay for $23 including shipping.  Looks great, feet touch the ground and I didn't have any poor handling as the result.  I did have to ream the inside of the bushing that was supplied for the bolt to fit through it however.
Good luck.
Offline Soos
« Reply #4 on: July 01, 2007, 10:26:34 AM »
If you have origional(or heavily worn aftermarket ones), mabey a set of shorter shocks would work, and give you better shocks in the process.
Personally, I do not like the thought of lowering blocks as it tends to offset the position the shocks mount on the rear swingarm.
It probably doesn't make that much difference in handling, or reliability.(dunno, never tried them)
Shock lowering blocks just seem the cheap/easy way to acheiving what a new 1" or 2" shorter set of shocks will give you.
just my .02....
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
