Author Topic: 76 CB750F brake caliper question  (Read 2424 times)
Offline starion88esir
« on: June 16, 2007, 05:07:47 PM »
Is there any other more readily available caliper I can directly bolt on to my 750F? My bleeder screw broke off in my caliper. So it's over and done with.  Or is there a source for these? I don't want to buy some old crusty one to have this happen, again.
71 CB175 - next project
76 CB750F - current project
Offline 75750SS
  • 75 750F, 2010 Concours ABS
Re: 76 CB750F brake caliper question
« Reply #1 on: June 16, 2007, 05:11:40 PM »
Is it just the bleeder you looking for?  The Speed Bleeders work great!
Offline jaym
« Reply #2 on: June 16, 2007, 05:32:15 PM »
take a slow deep breath...then spray the heck out of the busted bleeder screw.  take a drill bit and drill the center just to rough it up from the spray and it will also generate some heat, then put an easy out into it and twist it out.  moving forward, that caliper is on the all of the later cb750 K and 75-76 F models...find one on ebay that looks better than yours. clean it, bead blast it, put in a new seal, clean up the best of the two pistons you now have , etc and you will have fine brakes for  a long time.....
"accomplish what is important, not what is urgent"
« Reply #3 on: June 16, 2007, 05:59:39 PM »
On the K models as well? So the rear caliper is the same as the front? Or did you mean later as in 77 up K models (not sure when/if they switched to rear disc) I need to pick up an easy out with as much stuff that breaks on this bike.
Offline siter81
  • vintage bike junkie!
  • TOO MANY BIKES? NEVER
« Reply #4 on: June 16, 2007, 06:25:43 PM »
  Easyout,     One of the best tools i have bought. SAVED MY A=S MANY A TIMES.
ALSO THE MIGHTY IMPACT WRENCH. ;D
Siter81       8) 8)
61 BMW R27 70 BMW R75/5  75 RD350
71 SUZUKI T500
75 CB750K5  Weisco 836, WEB CAM.DYNA IGN,KERKER,K&N,TAYLOR,GALFER,AGM ETC.
 01 HONDA VC11000C3 AERO.
74&75 DUCATI 860 GT'S
« Reply #5 on: June 16, 2007, 10:17:17 PM »
If you can't get it out or want it done, send it to Speed Bleeder. For the price of a bleeder (~$10) they will remove it for you and install the Speed Bleeder. How can you beat that?!
« Reply #6 on: June 17, 2007, 02:45:58 AM »
look up a post cliper bleeder
Offline KB02
« Reply #7 on: June 17, 2007, 05:58:10 AM »
Siter81       8) 8)
Easy out - One of the worst pieces of Sh*t I ever spend money on. I have NEVER had a situation to use an easy out where that damned things actually worked. Usually they just make the situation worse. Don't waste your money on a set, save it for Ebay to get a new caliper.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
« Reply #8 on: June 17, 2007, 09:12:36 AM »
Siter81       8) 8)
This has been my experience the one or two times I borrowed one. I just attributed to operator error. I'm glad to hear others have had the same experience and it's not just me.
At $10 for a speed bleeder and the cost of shipping, I think I've found the best route to go. Now to track down a nice (preferably NEW) piston for the caliper.
